Are 96 and 97 the same?
Old Dec 11, 2005 | 06:46 PM
trike1946's Avatar
trike1946
Question Are 96 and 97 the same?
I have a 96 E-350 and am thinking about a 97 E-450. Are they the same except for suspension? Same HP etc.? I know they are both 7.3 with E40D. Does the 97 have a block heater? Thanks for any help.
Old Dec 11, 2005 | 07:52 PM
BltFordTough's Avatar
BltFordTough
The 97 should have a block heater and same HP. The E-Super Duty does have a heavy duty suspension with a 14,050 GVW if thats what you are thinking E-450 wise.
Old Dec 11, 2005 | 08:33 PM
trike1946's Avatar
trike1946
It doesn't say super duty on it. Can it be an E-450 and not a super duty? My reason for going bigger is for more towing. I want to tow 12K.
Old Dec 11, 2005 | 09:13 PM
BltFordTough
I looked in my 1996 dealer manual and it said 350 and super duty. Its possible that they had a 450 im not sure. Does it say 450 on it ?
Old Dec 11, 2005 | 09:19 PM
1997F-350's Avatar
1997F-350
96=215 hp
97=225 hp
i dont have any van specs.... but the most my truck says to tow is a trailer weighing no more than 13,500. it all depends on tranny and gears. of course people tow a lot heavier loads than this all the time.
my owners manual lists a 450 and superduty for 97????????????
Old Dec 11, 2005 | 10:00 PM
oldbird1965's Avatar
oldbird1965
I didn't think SD started until 99? How do you tell if you have a SD or not? Almost every time I go to the parts store for my 96 they ask me if its a SD.
Last edited by oldbird1965; Dec 11, 2005 at 10:04 PM. Reason: add my year, you didn't add my signature
Old Dec 11, 2005 | 10:03 PM
1997F-350's Avatar
1997F-350
not is called a f-superduty....next time you see an obs flatbed tow truck look at the fender badges.
Old Dec 12, 2005 | 07:46 AM
Dan Ryan's Avatar
Dan Ryan
Smile
Hi All
I have a 97 PSD, my brother has worked on Fords for over 30 years. He has stated that the (7 PSD did come with a block heater, so far I haven't found it. He said it is above the oil Filter, I just changed the oil filter, and didn't see one, but since I am new to a Diesel, I'm not to sure what I looking for. I did notice that on the oil filter housing, that a heavy duty flat Red wire was coming out of the side of the housing, could that be it, I haven't been able to trace the wire, will have to remove the air filter box to be able to see underneath there, and to see if I can find a plug. Any Help would be appricated. Thanks. My 7.3 is the second love of my life. Dan
Old Dec 12, 2005 | 08:35 AM
jimkidd's Avatar
jimkidd
There is one different.
Old Dec 12, 2005 | 10:25 AM
1997F-350's Avatar
1997F-350
Originally Posted by Dan Ryan
Hi All
follow it forward... no need to remove airbox it runs along the frame. its probably in your front bumper.
Old Dec 12, 2005 | 09:12 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The E/F-Superduty prior to 99 is a 450, no matter how it is badged.
OldWoodsDiesel
Aug 22, 2013 10:12 PM
twags6
Dec 7, 2011 09:01 PM
Paints-n-cows
Nov 14, 2009 12:49 PM
