9" rear disk brake kit
I had planed on just getting a different backing plate and going to 2 1/2" drum brakes. I have called all over and find they dont make them for the early 9" big bearing. Here is a link to the company
http://www.steeltechsolutions.com/
Has any of you done this? What are your thoughts ,
Thank you, bruland
The best truck show on earth.From what I have read, You have to buy parts from different places. The pre 68 9" rears had a smaller brake size and axle offset than post.
Maybe oneday soon, someone will have everything needed.
John
Disc brakes will not be a bolt on project, and they will give you less than desireable results. Notice that very few if any factory trucks have rear disc brakes - there is a reason for it. They are not practical for a truck, and if not set up precisely correct, can be dangerous. My observations from those who have done it for street trucks have been that they will give you more grief than help.
My advice would be to put your dollars and efforts into something which would give you more returns for the money.
Just my opinions.
I don't know what your truck's current configuration is, but you might want to consider upgrading to power steering, front disc brakes, electronic ignition, perhaps even a complete body swap onto a '73-'79 frame.
There is a tremendous amount of wonderful information here on FTE, so jump on in, the water's fine!
I have a 64 F100, 223, short box, with a Dana 60
4:56. Why anybody would order the truck with the
Dana B5 code. The truck came out of Washington State
and the cab and box are so straigth that that could of never
of been used to haul very much. The frame still has a factory
paper tag on the inside right frame rail that warns not to drill
holes in the frame.
It's time to move to the front of the truck.
Thanks for the help,B
I was assuming also that you had a 9" rear, and that you had a front twin I-beam suspension.
Since you have a '64, pay attention to the advice here at FTE, make usre that you are reading advice for a '64 and earlier, not for a '65 and later.
Good luck to you!
Additionally, you will have the wider rear brakes, and you will have a much wider choice of rear end ratios.
The only concern I would have is whether or not the spring perches are the same, especially as it applies to width, between a Dana and a Ford rear axle, specifically in your application. I am told they are the same, but it never hurts to measure twice and cut (or remove and re-install!) once.
