AIH - delete or not?
Old Dec 11, 2005 | 10:39 AM
guzzle92's Avatar
guzzle92
I was planning on deleting my AIH and use the port for my boost guage. With the cold weather we have been experiencing lately, I've been wondering if this is a good idea or not. We saw 15 below last week and have seen 25 below in past winters.
Would I be making a big mistake by deleting this heater with these conditions?
Old Dec 11, 2005 | 10:44 AM
Kwikkordead's Avatar
Kwikkordead
That's a tough call for me. Not very experienced with weather that cold, lived in Seattle all my life. If I was to try it I would keep all the parts neccessary for restoration just in case it doesn't work out. At the very least I would leave the EBPV in place.
That said, it probably would be ok if you have a load all the time, to make the engine work a little harder than usual. It needs to generate heat.
Old Dec 11, 2005 | 11:01 AM
Fordafied's Avatar
Fordafied
I was also wondering what the “actual” gain for this mod is. I know it helps air flow or suppose to. Does anyone have any factual data? I don't do mods just so I can state I have them. Now if they are proven to be a benefit, I will do them.
Old Dec 11, 2005 | 12:04 PM
clux's Avatar
clux
JMO, but having done the AIH delete, I think it is a waste of time.
You can use the same drill and tap that you used to install your pyrometer probe to drill and tap a hole in you intake horn for the boost, or splice into the map line.
Old Dec 11, 2005 | 05:53 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
that coil that the AIH used, was very large, and it had to be restrictive. i just used the plug from blackclouddiesel, and it works well. i still have the element. i would experiment for a week- unbolt the wire loops, and just tuck them out of the way. if you see blue smoke or white smoke during normal warmed-up operation, it is safe to take it out. if you see blue/white smoke, chances are is that the air is too cold that is going into the engine (rarity) and not making a clean/efficient burn.
Old Dec 11, 2005 | 06:16 PM
wlihntr's Avatar
wlihntr
take it out. it is only there to reduce smoke during warm up and has nothing to do with starting. its more of an image thing than a nedded function...$40,000 trucks shouldn't smoke when they are cold.
ps. ford added the AIH the International engines do not have them.
Old Dec 11, 2005 | 06:45 PM
guzzle92's Avatar
guzzle92
Thanks for all your opinions, that's what I was looking for. I think I will try removing it, use the BCD plug I bought and see what it does. Everything I remove, I keep intact so it won't be much to put it back if needed. I didn't want to try it if some folks had major problems in cold weather without it. Thanks again ....
Old Dec 11, 2005 | 07:24 PM
edub32's Avatar
edub32
BCD "claims" a 20% airflow but idk if thats true or not.
PowerstrokeJunkie
have you seen how massive that thing is?
Old Dec 11, 2005 | 08:00 PM
clux's Avatar
clux
Yeah, and they sell plugs for the port. it might be an issue if it was on the intake side of the turbo, but this thing is in charged side of the intake system. At positive pressure (boost) the heater isn't going to stop any air from getting into the cylinders.
I saw absolutely no effect from removing it, other than my pickup smokes a LOT more when it's cold out.
Old Dec 11, 2005 | 08:14 PM
PowerstrokeJunkie
good point. i didnt take into consideration that the air was pressurized and was going to go right around it.
Old Dec 11, 2005 | 08:21 PM
guzzle92's Avatar
guzzle92
My take on it after spending 23 years in HVAC, a restriction in the cold air return (intake) or heat duct (exhaust) is still a restriction and will effect air flow. With reguards to the AIH, I do not have any idea of how much that restriction would affect performance.
Old Dec 11, 2005 | 08:54 PM
kilapapipa's Avatar
kilapapipa
I haven't noticed a diff in operation or smoke since the removal of it and it gets plenty cold here. From the size of it, it had to be restricting air flow.
Old Dec 11, 2005 | 09:05 PM
Orezona's Avatar
Orezona
Wasn't another original reason for this mod that it tends to deteriorate over time and come apart in the system?
Old Dec 11, 2005 | 09:36 PM
Kwikkordead
Well that wouldn't be any fun.
