engine temps
Old Dec 31, 2005 | 02:47 PM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by PSD97
Also, I heard somewhere that one should not block the radiator partially, say 3/4, because the remaining airflow will be twisting your cooling fan unevenly especially at high speeds, resulting in waterpump bearing failure. Don't know if this is true in our engines.
That makes sense to me. Maybe get a piece of cardboard that is big enough to block the entire radiator and cut a hole out in the middle so the airflow will pass over the clutch fan unit and a little more. So it's pulling the air right out of the middle.
Old Jan 7, 2006 | 11:53 PM
94 1/2 stroker's Avatar
94 1/2 stroker
Just replaced thermostat,and man I forgot how hot the heater got. Used to run in between the low mark and the n in normal. Now it is on the r. Now while I was in there I seen oil at the bottom of the turbo and on the ebpv rod. Time to do a search on tubo rebuild. Thanks for the help fellas.
Old Jan 8, 2006 | 07:43 AM
tjbeggs's Avatar
tjbeggs
stock thermostat for the obs is a 203 stat!!! also the napa stat is a 203 and the stat sold on the site you guy were talking about is for the superduty unless they have gotten another one in for the obs. they are different. i guess i will go see if they have them now for the obs.
stroker glad to hear that your problems are fixed!
Old Jan 8, 2006 | 07:48 AM
tjbeggs's Avatar
tjbeggs
ok so i checked the site and its 96 and up that have the cold stat in them. but if you truck in a 94.5 you may have the wrong stat if thats the one you got.
Old Jan 8, 2006 | 08:26 AM
1997F-350's Avatar
1997F-350
mine was doing the same...thans to cookie i unplgged the plug right below the compressor side of turbo and no more leaky......its the plug for the ebpv actuator..hope this helps.
Old Jan 9, 2006 | 11:05 AM
1969fordguy's Avatar
1969fordguy
1994 1/2 Stroker have you noticed an increase in your mileage with the new thermostat??
Old Jan 10, 2006 | 01:54 AM
94 1/2 stroker
Sorry Fordguy I havent gotten to drive it since sat night on the test drive. It will probably be two weeks before I can go through enough fuel to check.
Towzilla
May 26, 2014 07:25 AM
reifwj
Mar 26, 2008 07:42 PM
irishkev
Modular V10 (6.8l)
Dec 2, 2007 09:40 AM
BuickTurbo
Sep 20, 2005 09:25 AM
morrigj83
Mar 20, 2004 08:41 AM
