391...?
Old Dec 9, 2005 | 07:09 AM
Mtthwvn73's Avatar
Mtthwvn73
391...?
hey i was wanting to what's the major difference between the 390 and a 391, i know the 391 is a heavy duty motor, but what's the big differences?
thanks,
matt
Old Dec 9, 2005 | 08:52 AM
66beater's Avatar
66beater
391 is a FT series. webbed block, but interchangable with a normal FE block if an adaptor ring is used for the distributor. Distributor has a thicker base, but an adaptor ring is avalible to run the smaller FE unit. Forged crank, externaly balanced. crank has larger snout, so bigger hole in a cast timing cover. Crank can be used in a normal FE with either some minor machine work, or use of the FT's timing cover. The heads and intake manifold are diffrent, interchangable with a standard FE, but only as a set.
Old Dec 9, 2005 | 10:52 PM
Randyb12's Avatar
Randyb12
The 391 is a heavy duty FE with low performance heads and intake and big heavy cast iron timing cover that doubles as a motor mount. The block has higher nickle content and heavier block reinforcement. Some people use the blok and crank to build high power FE's. But like stated above you need the bushing for the FE dist and you need to have the crank turned down to fit in the FE timing cover. Most people have the crank internaly balanced.
Old Dec 9, 2005 | 10:55 PM
ron_29_1973's Avatar
ron_29_1973
also the 361 and 391 uses a steel crank and has 4 rig pistons real good pulling eng
Old Dec 9, 2005 | 11:33 PM
ford390gashog's Avatar
ford390gashog
not all are 4 ring. the FT engines are very low power low rpm low compression engines. they all make less power than the FE engines.
Old Dec 9, 2005 | 11:50 PM
ron_29_1973
all 361 and 391's a 4 ring pistons
Old Dec 10, 2005 | 12:18 AM
ford390gashog
actually plenty had the C7 deep dish 3 groove pistons. 4 groove was a special thing for the mot part but common in dump trucks and water pumps.. U haul used both but mainly 3 groove. plenty of school buises are still running the 391 with 3 groove. both were common.
Old Dec 10, 2005 | 12:27 AM
ron_29_1973
all i ever seen was 4 ring but who know's were talking about ford's so anything is posable
Old Dec 10, 2005 | 10:24 PM
Mtthwvn73's Avatar
Mtthwvn73
lol...thanks for the help, so it's pretty much a heavy duty 390...right? and same for the 360. what about the bore and stroke...are they the same? could i put 390 pistons in a 391 block?
Old Dec 10, 2005 | 11:16 PM
ford390gashog
yes you can use the 390 pistons. but i would use 360 pistons. the ft is different in lots of ways .
1972RedNeck
Apr 21, 2013 11:15 PM
72crew
Mar 10, 2006 07:29 PM
brownfoot
May 14, 2005 10:51 AM
2speed
Feb 6, 2003 10:40 AM
fordguy76
33
Jul 26, 2002 09:20 AM
