ALMOST stalls, occasionally?
Old Dec 16, 2005 | 10:35 PM
PSNut's Avatar
PSNut
Originally Posted by Powerstrokedlariat
That sounds right, it does give a lugging feel before it goes forward, but this week it has decided to finally stall me out....
OK...so it runs good at higher speeds?...but stalls when going slow...yup...sounds like t/c issue. Hey...maybe it's time for an upgrade on the T/C...it's telling u something...the wife will never find out.
Old Dec 16, 2005 | 10:38 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
How right you are !!! T/c was supposed to be a heavy duty unit from Ford but I dont think there is such a thing. I will look into that, thanks for your help PSNut!!
Old Dec 17, 2005 | 01:05 AM
PowerStrokeMe's Avatar
PowerStrokeMe
Mine has been doing something like this lately too. Drive for a while and come to a stop light. The truck hesitates for a second like its going to die but keeps running. Other times it will just be idling and it dies. I have a backup CPS just in case it is that since I have heard those are some of the symtoms. Is this what your truck is doing also? Mines a 6spd tho.
Old Dec 17, 2005 | 01:23 AM
Powerstrokedlariat
Interesting, those are my symptoms all right. It has never died when idling, just when I step on the go pedal. Then tonight, when I put it in reverse, it died completely. I think that tomorrow I will replace the CPS with my spare and see if the symptoms go away. I will report back if anything happens. Lets figure this out!! Truck can not randomly die like this, we all have work to do!!!
Old Dec 17, 2005 | 01:31 PM
Powerstrokedlariat
Powerstrokeme- I went to the dealer this morning (I have a buddy that works there)and they think that my problem is a solenoid of some kind in the tranny hanging up. It will all be covered under warranty so it will head on in after x-mas. I mentioned your symptoms and they think it will most likely be your CPS, since the 6spd rules out the tranny. Start there, since you already have a spare. I will report back with any further knowledge or info. Thanks guys
Old Dec 17, 2005 | 06:28 PM
PowerStrokeMe
Hey thanks for the info! Its too freakin cold here to be crawling around under the truck even for 5 minutes so hopefully it will warm up soon. My service engine soon light comes on every once in a while too so I dont know if its a combo of the CPS and chip. Probably go to autozone and have them pull the codes when it does it again and Im not on a tight schedule Thanks again!
jds872
Aug 12, 2015 01:15 PM
swartzad
Nov 6, 2014 04:33 PM
CGM
Sep 26, 2011 08:38 AM
dieterschmied
Apr 19, 2011 08:15 AM
rungunner
24
Mar 13, 2009 05:20 PM
