no brake pedal return?
Old Dec 8, 2005 | 09:14 AM
busted knuckle's Avatar
busted knuckle
78 f150 pwr brake 400 c6 4x4 new rear hardware, new calipers, new mc ,new wheel cylinders
the problem} i have a firm pedal, good pressure from all bleeders but the pedal itself does not return back causing the brakes to stay partially engaged. is it the
linkage? an adjustment? bad booster? what other options do i have?
thanks alot guys
Old Dec 8, 2005 | 09:18 AM
highway90's Avatar
highway90
I just had the same thing happen to me. It ended up being a bad booster. btw.. I had just bought a rebuilt booster 2 weeks before from Autozone. I guess it was a defect part. They are not too expensive considering.
Also, check to see if the pedal come up some with the engine off vs on.. This will help you diagnose. and use this site.
http://www.classicperform.com/TechBook/BrakeTroubleshoot.htm#testbooster
74 F100 351m's Avatar
74 F100 351m
The linkage behind the booster was rusted on mine, a little sandpaper and some neversezze di the trick for mine.
Old Dec 8, 2005 | 11:39 AM
busted knuckle
thanks guys
gerrbear78
Feb 5, 2026 10:00 PM
canadian_diesel1964
May 6, 2014 07:49 PM
canadian_diesel1964
Oct 28, 2011 12:32 PM
firemanp
Sep 22, 2010 07:15 PM
jww233
1997 - 2003 F150
Jan 2, 2006 05:14 PM
