Gear Box
Old Dec 7, 2005 | 02:29 PM
77300i6's Avatar
77300i6
Red face Gear Box
Lately my power steering fluid has been leaking a lot worse. It used to be a slow leak, but has gotten out of hand now.
The source of the leak is the bottom of the sector shaft. So, I guess I will be replacing the entire box. While I'm at it I will also replace the the P/S pump, hoses, and install an inline filter. I searched for a loooong time on here, and it seems that the Saginaw pump is the way to go. I also have come accross the Ford HD P/S pump as it is basically a Saginaw unit with a different casing that will bolt up in place of my old pump. I came accross an old thread that someone had pointed out that you can only hook up a Saginaw pump to a Saginaw box or else there would be steering bindage and other problems. Has anyone else heard of this?
My truck is a '77 with a build date of 02/77. I heard that at one time Ford used Saginaw pumps, before switching to their intelligently designed () pumps that most of us are stuck with.
Where would be the best place to buy a gear box, and will a Saginaw pump cause problems with a Ford box?
Thanx in advance for you help.
Bill
Old Dec 7, 2005 | 05:14 PM
1975Ford's Avatar
1975Ford
I'm thinking of a swap of some type of saginaw pump setup on my 75 F250 4x4 Hi Boy w/390cid
https://www.ford-trucks.com/forums/s...3&page=1&pp=15
It was mentioned on forum, not sure where, but swapping a power steering pump with a divorced fluid reservoir.
BCHauler
31
Jul 30, 2022 10:21 PM
Norton72
Offroad & 4x4
Dec 29, 2013 05:33 PM
bajafishnut
Jan 30, 2013 08:47 PM
cje07
1978 - 1996 Big Bronco
Sep 1, 2007 09:12 AM
Scouder
Mar 24, 2002 08:26 PM
