Power Steering Pump Bracketry
Old Nov 8, 2005 | 11:59 AM
workingdog's Avatar
workingdog
I'm putting power steering on my 390 and I am having a real hard time finding anyone that makes a bracket for mounting a Saginaw to the 390. We're going to the Pick'n Pull today to see what we can find - but does anyone know of a source for these?
Old Nov 8, 2005 | 01:26 PM
Scouder's Avatar
Scouder
I have been told that they exist, but I was unable to find any information on it when I looked. I think people were confusing the FE with some other engine family. Good luck.
-Scouder
Old Nov 8, 2005 | 01:28 PM
fordraceboy's Avatar
fordraceboy
do you mean the bracket thats on the motor or the bracket that bolts to the pump itself?
Old Nov 8, 2005 | 02:21 PM
workingdog's Avatar
workingdog
The bracket that mounts to the motor and to the pump that holds the pump in position.
Peter
Old Nov 8, 2005 | 03:54 PM
fordraceboy
i found some info on putting a saginaw setup onto a small block and that wasnt very promising even in that useage.. said it was kinda expensive or you would be modifying and fabbing your own... it wont let me post that link for the info i found so go to google and type in saginaw power steering pump and then when your results pull up go to the classicbronco choice...
is it going on your 68 F250 4x4?
Old Nov 8, 2005 | 07:05 PM
428FE_Freek's Avatar
428FE_Freek
I don't remember the years, but the older E series vans had the saginaw pump. Maybe someone else can elaberate further.
Old Nov 9, 2005 | 01:57 PM
1975Ford's Avatar
1975Ford
A 78 and upward years of Ford E-250 (3/4 ton) and Ford E-350 van with a 460 cid and 351M cid has the saginaw powersteering pumps and brackets. Will also need the power steering hoses (hi pressure and return lines)
Old Nov 9, 2005 | 02:01 PM
1975Ford's Avatar
1975Ford
here a site with and aftermarket pump http://www.performancecenter.com/aut...agr847257.html
Old Nov 9, 2005 | 02:05 PM
fordraceboy
the bracketry from a 385 series motor or the M series is quite a bit different than an FE setup, although i'm not looking at a saginaw setup either.. just curious, why go to the saginaw style pump? already have one laying around you can use?
Old Nov 10, 2005 | 11:47 AM
1975Ford's Avatar
1975Ford
Also some early Bronco with a 6 cylinder came optional with the siginaw powersteering.
Old Nov 13, 2005 | 12:01 AM
bob arrington's Avatar
bob arrington
you dont really need the saginaw unless you are running tires taller than 33'. or you have some caster problems that are better fixed,bob
Old Nov 13, 2005 | 12:04 AM
fordraceboy
i run 38.5x15's on my f250 and don't have any problems at all... steers great.. jmo
Old Nov 21, 2005 | 11:13 AM
1975Ford's Avatar
1975Ford
Here are some factory installed Saginaw pumps for the Econoline and Broncos.
https://www.ford-trucks.com/user_gal...&albumid=18853
Old Nov 22, 2005 | 08:45 AM
workingdog's Avatar
workingdog
But I don't think any of those pictures is for an FE - is it?
Peter
Old Nov 22, 2005 | 01:57 PM
fordraceboy
didnt make saginaw for an FE so anything you get is a modification situation.
