Distributor gear question
Old Dec 5, 2005 | 01:07 AM
brett_d's Avatar
brett_d
Anyone know if the 1981 5.0 f-150 came with a steel gear stock from the factory? I am in the process of swapping in a 92 roller 5.0 and it requires a steel gear. I have no idea if it is steel or cast! I assume the distributer from the 81 will work in the 92 since it is carbed right?
Old Dec 5, 2005 | 05:50 AM
stevef100s's Avatar
stevef100s
Flat tappet cam and roller cam cannot use the same distributor gear. You'll need to replace yours.
Old Dec 5, 2005 | 05:52 AM
ken75ranger's Avatar
ken75ranger
A stock 81 will have a cast gear. You can get a steel gear and replace it or get a distributor for an '85 mustang with a 4 barrel carb. There are plenty of aftermarket one's too. I'm running a Mallory 1 wire HEI.
Old Dec 5, 2005 | 10:38 AM
Blurry94's Avatar
Blurry94
Honestly, it's less of a hassle to just buy a new core with the steel gear on it. I think they run around 80 bucks from your local parts store, and all you have to do is stab it.
Old Dec 5, 2005 | 11:07 AM
charliehorse's Avatar
charliehorse
Drop me a nnote if you want a steel gear. Had gotten one from JEGS, a Crane steel gear for a .467 shaft and then discoverd our 77 distributor was 1/2 in shorter than what the '90 motor needed. SO we bought a Mallory dist witha steel gear already on it. Don't need the other steel gear now.
tonkyman
Jul 18, 2013 08:31 PM
jlsk8ter
Feb 8, 2011 03:14 AM
joelfx4
Aug 26, 2010 12:49 PM
bookpile
Aug 1, 2010 11:45 AM
77effie
17
Mar 27, 2006 10:36 AM
