Distributor cast iron or steel gear??
I have a 1990 F150 5.0L How do you know if it has a steel gear or cast iron gear on the distributor shaft??
I ordered a complete distributor with a steel gear from O'Reilly Auto parts but after looking around a bit I saw a warning that says
Tony
- Cast Iron And Steel Gears Are Not Interchangeable
- Use Of Incorrect Part Number Will Cause Severe Damage To Camshaft Gear And/Or Distributor Gear
Tony
Another way to check what cam you have now is to pull valve cover and look at the wear pattern on the top of the pushrod under the rocker arm. With roller cams, the lifters dont spin in the bores, thus the pushrods dont rotate, allowing for a wear pattern to develop, which is easy to see.
May try using the search function to help.
Just checked the O'Reilly website and searched your year, make, and model. Both of the A1 Cardone distributors are cast iron and the one by RPT with the steel gear is 45$ cheaper than the other by RPT with cast iron gear. I would be inclined to check and see if they have the other available. Also if needed, you can swap the gear from either of the 2, but be sure to identify which is which so as not to get them mixed up.
The gear depends on the cam you have. The stock gear is cast iron and you need to use that. One word of caution...when you replace a gear it had better be on there perfect or it will eat the gear on the cam (happened to me,I ended up buying a whole new dizzy from MSD so I didn't eat another cam )
Well... I thought it was to good to be true. A complete distributor for $80 bucks. I guess I'll send it back and pay the $150 for the other one.
I'm not opposed to changing the gear if it's nothing more than driving out a drift pin. Is the gear pressed on the shaft or just a snug fit?
Thanks for your help.
Tony
Tony
gnwalker
01-23-2010 11:44 AM
meb9796
06-13-2008 10:35 PM
Jrock909
01-23-2007 08:36 AM
lmadore
10-25-2005 07:53 AM
