fomoco powered bowtie
Old Dec 4, 2005 | 07:59 AM
travisshaffar's Avatar
travisshaffar
i have a 1988 chevy extended cab 3/4 ton 4x4, can i put my 6.9 in it and still keep my chevy 5 speed? anyone ever trie it?
Old Dec 4, 2005 | 10:20 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Man that is not going to go over well in the Chevy camp.
You may be able to get the adapter at http://www.AdvanceAdapters.com
Old Dec 4, 2005 | 12:38 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Welcome to Ford Truck Enthusiasts travisshaffar.
The bolt patterns are not the same, and there may be clutch issues as well, but like Dave said...there might be adapters available. Is using a Ford five speed not an option?
I like this thread a lot better than the "cummins in a Ford" thread we had the other day.
Old Dec 4, 2005 | 10:18 PM
wh336fire's Avatar
wh336fire
Wink
Now Mr Scott , cummins is a sweet engine .
Old Dec 4, 2005 | 11:34 PM
Dave Sponaugle
Matter of opinion.
I think my 6.9 turbo is a sweet engine.
Old Dec 5, 2005 | 10:10 PM
cookie88's Avatar
cookie88
FTE Emeritus
It may be, but this is the tech forum for the 6.9 and 7.3 IDI. The only places the merits of the 5.9 should be discussed are the general diesel and Ford vs. the competition forums.
Old Dec 8, 2005 | 08:34 AM
travisshaffar
i would love to use a ford 5 speed, but then my transfer would be on the wrong side wouldnt it?
Old Dec 8, 2005 | 09:14 AM
cgrandahl64's Avatar
cgrandahl64
im not up pn the interchangability of these engines with the trucks oem tranny/clutch/transfer case, but i do know how a pain some of this stuff can. I think that you would be better off using the whole ford setup (engine, tranny and tcase) . Im not familiar with the late 80's chevys, but if there is room for the whole ford setup, a couple driveshaft changes might be easier then mixing drivline compnets from diffrent oems.
Old Dec 8, 2005 | 10:55 AM
fellro86's Avatar
fellro86
I saw a chevy with a 6.9 in it on ebay just a week or so ago, but they didn't show much on the powertrain, so I don't know just what all it had in it. The bell housing is going to be the biggest problem, as the diesel is all by itself on interchange. I doubt there are any adapters readily available for that reason, and lack of real demand to do it. I think you would be best served to use the Ford trans, and then get an adapter for the t-case instead. Since the t-case has the driveshaft on the same side, you could use the Ford t-case as well, and then just make up driveshafts for it.
Old Dec 8, 2005 | 12:49 PM
wh336fire's Avatar
wh336fire
I think I would sell the Chevy and just buy a ford . If it was a classic truck , that would be a different story . I have seen an older Chevy crew cab 4x4 with a 6.9 .Not sure what tranny and transfer case he used . He may have changed the front axle .
Old Dec 8, 2005 | 07:42 PM
Dave Sponaugle
I think the front punkin is on the other side on a Chevy.
I know it is on a Dodge.
So that would make it hard to use a Ford transfer case.
Old Dec 8, 2005 | 08:04 PM
fellro86's Avatar
fellro86
88 the pumpkin got moved to the driver's side, prior to that, it was passenger.
Old Dec 8, 2005 | 09:00 PM
Raceallday's Avatar
Raceallday
Technically, the 6.9 is not even a Ford engine is it? I thought the 6.9 and 7.3 are International?
Old Dec 8, 2005 | 09:23 PM
fellro86's Avatar
fellro86
Technically, they are IH, but many people don't differentiate that. Ford hasn't built their own diesel for since the 70's, except the tractors, and even those I'm not certain about.
f150crawler4.9
Feb 26, 2013 04:06 PM
fish-albuq
Aug 29, 2012 05:25 PM
nitro_rat
Offroad & 4x4
Apr 25, 2012 09:02 PM
CA55F100
Ford vs The Competition
38
Jan 22, 2007 11:22 AM
460429_freak
15
Feb 12, 2003 08:42 PM
