Offroad & 4x4
dana 44 8-lug with chevy parts
Old 08-22-2008, 09:55 PM
nitro_rat's Avatar
nitro_rat
nitro_rat is offline
I got a set of chevy 3/4-ton outers for my 74 f-100. good-bye drum brakes! does anybody know if the spindles and backing plates will fit my knuckles? if i have to use the chevy knuckles and stub shafts, is the tie rod taper the same, or will i have to do some steering fab work? i know someone has done this!
Old 08-22-2008, 10:26 PM
Truckin4life's Avatar
Truckin4life
Truckin4life is offline
Street Queen to the extr3m3
...... ugh..... I dont recall specifically, but im thinkin it wont work together. I could be completely wrong though. Best way to find out would be do it. If it does work, then come back and let us know.
Old 04-25-2012, 02:38 PM
lasthighboy's Avatar
lasthighboy
lasthighboy is offline
i see this is an old post, but did you ever get it done? I think it could work, I know a guy that has used interntional 8 lug knuckles on a half ton ford. Interesting to find out...
Old 04-25-2012, 03:02 PM
nitro_rat's Avatar
nitro_rat
I think the chevy 3/4 ton backing plates and calipers will work with ford 5 lug hubs/rotors. Got a good deal on a 1/2 ton ford axle with 3/4 ton ford outers for that one. Incidentally the 10.25 sterling from 80-97 style trucks bolt into dents. Im sure they'll fit bumps too. Just need the larger diameter u-bolts.
Old 04-25-2012, 09:02 PM
kjett's Avatar
kjett
kjett is offline
I know the late 70's D44hd 8 lug knuckles and outter parts will fit a late 70's D44 half ton. It's the earlier D44's (like the 70 model I have here) that you have to watch for as u-joint sizes are different as well as some of the knuckle parts. If it's just a drum to disk conversion you want, the popular conversion on the 1/2 ton stuff is to keep the drum spindles but swap over to chevy 1/2 ton caliper brackets and calipers using the later 78 and up hubs/rotors. It's a bolt on deal and failry straight forward to do. The only thing on that is it will keep you at a 5x5.5 bolt pattern
timmwag
01-01-2010 10:45 PM
mizzitch
1999 to 2016 Super Duty
19
02-17-2009 02:44 PM
rocessk8r2
05-16-2008 07:16 AM
super440
Offroad & 4x4
09-20-2004 08:39 PM
Quick Reply: dana 44 8-lug with chevy parts
