Camshaft Replacement
Dec 3, 2005 | 07:23 PM
When replacing the camshaft in a Ford 352, is there a pin that holds it in place to keep it from moving and if so where is it located?
Dec 3, 2005 | 07:26 PM
nope. just the retainer that bolts to the front of the block.. not coming out?
Dec 3, 2005 | 07:32 PM
Some of the very early 352's used a different system. What year is it?
Dec 3, 2005 | 07:33 PM
Haven't tried yet going to try right now. Will be back with an update. Thanks so much for the info!!!!!!!!!
Dec 3, 2005 | 07:56 PM
most use 2 big phillips head screws
Dec 3, 2005 | 08:14 PM
those screws can be a pita! I use a pair of pliers or something similar on the screwdriver handle for extra leverage.
Dec 3, 2005 | 09:23 PM
i just grab the heads with a vise grip. i replaced them with grade 8 bolts.
Dec 5, 2005 | 04:10 PM
I use a hand held, hit it with a hammer impact driver, had bought it originaly to work on motorcycles, but always comes in handy on those screws
Dec 5, 2005 | 06:14 PM
I found that the impact screwdriver works the best too, i just had to remove a cam in a 360 4 days ago. Those bolts can be a pain!
Sheryle
Mar 26, 2013 11:21 PM
zief67
3.8 & 4.2L V6
Feb 26, 2011 12:02 PM
BrockwayMT
4 Cylinder Engines
Dec 14, 2004 08:08 PM
airharley
Dec 18, 2002 08:26 PM
