FE - Parts Identification For Rebuild
Old Nov 20, 2005 | 08:20 PM
ceetwarrior's Avatar
ceetwarrior
Exclamation FE - Parts Identification For Rebuild
Hey guys I'm rebuilding Spudco's old FE for my neighbor. I tore it down and need some identifying help.
Block - Part # is ground off
Heads - C8AE-H
Crank - 2U
Rods - C6AE-C
Rod Bearings - Ford C6AE-6211-S-T
Main Bearings - Ford 6333-AE-AF
Pistons - only say "390-2V" on the sides.
1. I don't have a mic, so are those bearings STD? They don't say anything about oversize.
2. Is that crank/rods combo correct for 390?
3. And what about the pistons, STD?
Thanks
Old Nov 20, 2005 | 08:32 PM
rusty70f100's Avatar
rusty70f100
You can never have enough tools. Go get yourself a mike, or at least a good digital caliper.
You have a 390 crank. You have 390 rods. You have 390 heads with 68-71cc chambers.
I would guess, based on the numbers, that the bearings are standard, especially if they're Ford bearings. Same for the pistons. Usually if things aren't standard, they wont be Ford parts any more. Example: Clevite bearings and pistons that dont say "390 2V" would indicate something different. But buy the tools and do it right.
Old Nov 20, 2005 | 09:00 PM
ceetwarrior
Thanks Rusty, I am going to buy a mic. I just don't have one tonight.
Everything looks decent on this motor and my neighbors on a budget. So,
- Crank will get emery polished, then new main bearings
- Pistons look good, bushings have no side slap
- Quick drill hone on cylinders, new piston rings.
- New timing chain,
- Oil pump is tight/clean,
- Not sure yet about cam or lifters. They appear not worn much. Nothin' worn near as bad as my FE was.
I guess I'm going to get parts from Autozone unless I can find 'em cheaper. $50 clevite main bearings, $26 Clevite Rod bearings, $20 stock timing chain.
Haven't even looked at the heads yet.
Old Nov 21, 2005 | 06:18 AM
fordeverpower's Avatar
fordeverpower
I recommend a 0-6 inch, .0001 micrometer set, if you are lazy then get a digital one that has accuracy to .0001. My digital only goes to .001, but its plenty handy for alot of quick measurements. My next tool needs to be a dial bore gauge.
As for the parts, sounds like it is bone stock. It is a 390 though.
Old Nov 22, 2005 | 09:51 PM
ceetwarrior
Ok, I bought a nice caliper today. Bore is 4.05", crank mains are 2.75", and crank arms are 2.436".
Is that all stock measurements?
Old Nov 22, 2005 | 10:00 PM
rusty70f100
Close enough. Stock dimension for the mains are 2.7488, and the rods are 2.4384. Looks like you have about .002" wear on the rods, if your caliper is correct. Take the reading in different places, and take readings 90 degrees apart. I think you'll be surprised. Kind of fun to see how they wear.
Old Nov 22, 2005 | 10:40 PM
ceetwarrior
Ok, well cool. Sounds like I'm ready to go buy some new parts. I guess I'm going to look into an RV cam now, I wonder if Autozone sells any good ones...
Old Nov 23, 2005 | 07:13 PM
fordeverpower
please do not buy a speedpro,melling, clevite camshaft. They are worthless!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Old Nov 23, 2005 | 07:47 PM
rusty70f100
I was going to say something, but I figure he's read enough to know what we think. If he doesn't want to believe it and wants to get a underperforming cam, that's ok by me.
-sigh-
Ok, I'd recommend you go with a Crane grind. The 343941 is recommended for towing, as is the 343901. Pick one to match your compression ratio.
Old Nov 24, 2005 | 08:00 PM
ceetwarrior
Oh for sure, I know to stay away from those things from what I've seen you guys say. This motor will have stock compression since it'll be using the original pistons etc. So what's that, 8.5:1? Where's the cheapest place to buy a crane cam?
Old Nov 24, 2005 | 08:22 PM
rusty70f100
Try Summit Racing, DSC, or Jegs. In that order.
Old Nov 24, 2005 | 08:32 PM
ceetwarrior
I'm checking Summit right now. Does DSC have a website?
Old Nov 24, 2005 | 08:40 PM
ceetwarrior
Rusty, what do ya think about Clevite P-series vs. Fed Mog on bearings? The Fed Mog are twice as much per bearing.... ?
Old Nov 24, 2005 | 08:51 PM
rusty70f100
Well, I have Clevite 77's in my engine, that had been in a box since about 1985. If what I'm reading on Summit is right, the P series should be about the same. They work, so that's what I recommend.
I got an old junkyard 360 for $35 a while back for spare parts to build my 390. It had badly damaged Federal Mogul bearings in it, with one spun rod bearing.
I'm sure lots of engines have gone lots of miles on either bearing. The above is just my experiences, for what they're worth.
Old Nov 24, 2005 | 09:04 PM
ceetwarrior
Cool, I just checked my bearing boxes on my build and I have Clevite 77's as well. On my build I used a EPWI cam, same grind as a CRN-343904. What do you think about that cam from the specs?
Well so far from Summit I've picked out:
CLE-CB760P rod bearings - $30
CLE-MS863P main bearings - $51
SUM-G6608 roller t-chain - $42
and still picking the cam
