swapping points for electrics
Old Feb 3, 2002 | 02:45 PM
gentle1's Avatar
gentle1
Post swapping points for electrics
74 ford 302-wanting to change over to elec.ignition.need to know what the best bang for the buck is.is this a dificult swap?thanks for any help
Old Feb 3, 2002 | 02:59 PM
Mil1ion's Avatar
Mil1ion
Look to your right at the TECH articles.
I'm sure all the info is there.
if not get back 2 us.
Dennis
Please Don't Ask Me Any Tough Questions As:
"I'm Saving My Memory For When I Develop Alzheimer's"
78 F-150 429CJ,Silver
w/Explorer Pkge.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Feb 3, 2002 | 03:29 PM
gentle1's Avatar
gentle1
thanks
Old Feb 3, 2002 | 04:50 PM
Leland's Avatar
Leland
On my 74 F100, 302, I had the ProBillet Distributor (model 8582) and MSD 6A Ignition box installed (model 6200). Also added 300+ Accel coil wire and Accel spark plug wires, and Autolite #45 plugs gapped at .044. Total was $400 for the above. I already had an Accel Super Coil.
Old Feb 3, 2002 | 11:04 PM
zs_tx's Avatar
zs_tx
petronix... i just did the swap myself in 15 minutes... takes no time and 80 bucks.. easy, simple and works like a dream... keep the same equipment, and just throw away points and condenser, insert little black box, and ring around the shaft, connect the wires, turn the key, and smile... that easy. petronix.. get it at o'reillys for $80
Old Feb 4, 2002 | 07:23 AM
hartmark's Avatar
hartmark
Pertronix...
http://www.vamustang.com/ignitors.htm
http://www.carshopinc.com/pertronix.shtml
http://www.vintageperformance.com/retrorockets/ford3.htm
Great prices on the net! I bought mine from VAmustang. I eliminated shipping costs by picking it up in person. I replaced the coil when I installed the ignitor. Took me a while to do as I had to bypass the resistor wire (the ignitor needs 12 v), but overall a VERY easy, cheap, and effective upgrade. If you need a new distributor, then go with one of the other options.
Mark
Old Feb 4, 2002 | 10:02 AM
74F250's Avatar
74F250
I just had to put new points and a condenser in my 74 because it was like someone was shutting off goin down the road and caused it to backfire and blew out my muffler. besides that i am looking at that petronix or whatever it is called.i would liek to dump the points. when i switched engines in my 79 firebird i put a 68 engine and pulled the points distributor and put in my HEI one form my 301 orginally out of the car. works great with out points
Old Feb 4, 2002 | 05:35 PM
nitrous125's Avatar
nitrous125
Biggest bang for the buck would be a Davis Unified Ignition man. You wouldnt believe the difference a DUI will make. If you decide to go DUI you'll thank me i promice you that.
Old Feb 4, 2002 | 06:53 PM
jowilker's Avatar
jowilker
Old Feb 5, 2002 | 09:05 AM
74F250's Avatar
74F250
where can i get some info on that at.
Old Feb 5, 2002 | 02:11 PM
gentle1's Avatar
gentle1
yeah i'd like to check that out too.thanks for your help.
Old Feb 5, 2002 | 03:52 PM
nitrous125's Avatar
nitrous125
at www.performancedistributors.com I would really consider it. I run one and it will really wake your motor up and give you better mileage at the same time. But the increase in power is amazing.
300FOREVER
1966 - 1977 Early Broncos
Aug 24, 2016 04:43 PM
Gater180
Sep 23, 2014 10:57 PM
deerfieldmike
Jun 23, 2014 07:47 AM
kitsapcountychopper
Mar 7, 2004 09:46 PM
