MAF removal
Old Nov 29, 2005 | 10:57 AM
lawnspecialties's Avatar
lawnspecialties
Unhappy MAF removal
I'm about to clean the MAF on my 4.0. I have everything ready except the security torx driver. It's hard enough finding a decent set of regular torx drivers but I've never even seen a security headed one until now. Where in the world can I get one?
Old Nov 29, 2005 | 11:51 AM
Bart99GT's Avatar
Bart99GT
Sears usually carries a set of tamper proof torx bits for about $20. You might check e-Bay if you know the exact size you need and only plan on needing the one bit.
Old Nov 29, 2005 | 01:16 PM
05ranger's Avatar
05ranger
sears has them...
Old Dec 1, 2005 | 09:28 AM
agryphon's Avatar
agryphon
I was able to pick up a set at Harbor Freight. You can prob order it online from a bunch of different places.
Old Dec 1, 2005 | 10:00 AM
rangerxlt02's Avatar
rangerxlt02
I've also heard of people taking a dremel and removing that security pin in the bolt, then a regular torx will work.
Just another idea for ya.
Old Dec 1, 2005 | 11:09 AM
larpa's Avatar
larpa
I picked up only the one I needed (3/8 drive socket) at Auto Zone!! Cost was about $5.
Old Dec 1, 2005 | 12:12 PM
Rockledge's Avatar
Rockledge
On all my Fords I have cut a slit in head of those dumb factory bolts and used a regular screwdriver to remove them, after which I threw them away and replaced them with similar sized phillips-head bolts and lock washers.
Aero-fan
Aerostar
Aug 26, 2010 01:46 PM
Outspoken1
Mar 2, 2007 09:07 AM
BottomFeeder
Jun 10, 2006 06:11 AM
RangerRuss
Garage & Workshop
Aug 7, 2003 08:08 PM
