what a difference
Old Nov 28, 2005 | 06:53 PM
puffer's Avatar
puffer
what a difference
i just relized, i have a down pipe exhaust leak right were the pipe mates with the turbo witch will get fixed tomorrow. the weird thing is i had the hyper tech contoller installed stage three and my bully dog came in. i installed the 75hp program and it was puffing black smoke and fluiding the engine because the turbo was spooling super slow, im guessing because of the exhaust leak. so i took down to the 50hp program and wow what a difference black smoke and was moving better than the hyper tech in stage three. but still a little slow due to the exhaust leak thats what im hoping is keeping the turbo from spooling up. i cant belevie how ****ty hyper tech in stage three is compared to the bully dog stage one. and i have some black smoke. do you guys think the exhaust leak is keeping the turbo from spooling faster?
Old Nov 28, 2005 | 08:18 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Unlikely a downpipe leak could prevent the turbo from spooling. Actually, it would spool faster without the downpipe.....less restriction.
Old Nov 28, 2005 | 10:15 PM
puffer's Avatar
puffer
i thought if the exhaust leaks out, it loses presure to keep spooling the turbo
Old Nov 28, 2005 | 10:25 PM
1997F-350's Avatar
1997F-350
where it comes out of the ebpv housing and meets up with the down pipe that exhaust there has already done its magic by then and is headed out your tail pipe.
now on the other hand if you have a leaky manifold, manifold to up pipe donut, up pipe to collector donut, or collector leak that is when you will be losing pressure that will affect you negatively.
edit: do you have a pic of where the leak is occuring? is there any soot. you may wanna climb under and over and do some looking for leaks at all the connections.
Old Nov 28, 2005 | 10:30 PM
puffer's Avatar
puffer
yes there black soot right where the v band bolt is
Old Nov 28, 2005 | 11:42 PM
watermanh's Avatar
watermanh
Yeah 1997's right. I had a leak in my exhaust manifold that I couldn't stop by just tightening everything down. Pulled the manifold this weekend and milled it, added a gasket, and it definitely made a difference in performance. You might want to take a close look around and try to see if anything else is leaking. I found mine when I was changing oil (cylinder above filter). Good luck, aloha.
Old Nov 29, 2005 | 07:51 AM
1997F-350's Avatar
1997F-350
did you ever find the part number for them? that is something that is not on my master list. and seeing how our trucks dont come with them i assume they are hard to find(ex manifold gaskets). thanks ryan
Old Nov 29, 2005 | 04:45 PM
mooktank's Avatar
mooktank
if it were me i'd slap some copper RTV on there with no gasket. A lot of turbo mustang guys are doin that.
Old Nov 29, 2005 | 10:41 PM
watermanh's Avatar
watermanh
I installed a FEL-PRO gasket, part #MS93489. I got it at a local Redline Automotive. These guys have just about everything I ask for in stock. I didn't go to the stealership, as it seems that no matter what I go there for, they need to order it. Hope this info helps, aloha.
Old Nov 30, 2005 | 11:39 AM
tjbeggs's Avatar
tjbeggs
generally if you put a gasket where the was previously not one it will blow out. if the manifold is milled and flat it will seal up without a gasket and last for a long time.
