Driveline producing harmonics.
Old Feb 12, 2002 | 11:20 AM
petem's Avatar
petem
My '76 F250 4WD is generating a slight ringing sound at freeway speeds at around 2500 rpm. I thought it was air whistling, but it disappears when the engine speed is changed. Could this be coming from one of the driveshafts?
Old Feb 12, 2002 | 11:24 AM
Ford79's Avatar
Ford79
Could be a u-joint. When they dry up, they tend to make a whistle/ring/chirp type sound.
Old Feb 12, 2002 | 09:01 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Pete, make sure the driveshaft(s) are in phase. The u-joint caps must be aligned with each other, (in a straight line, viewed from front to back).
Old Feb 13, 2002 | 11:54 AM
petem's Avatar
petem
Great-thanks for the advise. I not quite understanding the driveshafts being out of phase. If the u-joints caps are not aligned correctly, is it because the yokes are damaged or distorted? pete
Old Feb 13, 2002 | 09:01 PM
thelonerangerxlt
Hi Pete. The mis-alignment of the u-joint caps, looking along the driveshafts, is called "out of phase". This condition is caused by the slip joint being put together with the splines being one (or more) splines off from where they should be.
I'm not sure of your set-up, with the 2 driveshafts. But you will have at least 1 slip joint; on the rear-most drive shaft. You may have another where they meet up. Just make sure that the u-joint caps line up with each other. If you pull a string tight between the caps, the string must be exactly parallel to the drive shaft length.
Hope my explaination is not too confusing.
Old Feb 14, 2002 | 12:14 PM
petem's Avatar
petem
Ahhh-ok. I think I got it. I will check that. Actually my truck has three driveshafts-all with slip-splines and three u-joints per shaft. A lot of variables. Thanks again!
Old Feb 14, 2002 | 02:59 PM
Unleaded's Avatar
Unleaded
ANIMAL
Sep 4, 2002 03:31 PM
4_speed
Aug 25, 2002 11:20 AM
Yeti
May 17, 2002 04:16 PM
whiteboyslo
Nov 6, 2001 04:19 PM
slik
Oct 12, 2000 07:50 AM
