H5 axle code? 410 LS gears.
Old Nov 26, 2005 | 03:36 PM
scouterspokane's Avatar
scouterspokane
Question H5 axle code? 410 LS gears.
hey guys, the door jam reads as a H5, the axle tang reads as follows:
S815D
L1088
BA18
is the '88" the code for a ford 8.8?
and if so, what is a 8.8? and what can I do to this axle, for example, can I change anything in the pumpkin or the replace the whole thing?
the front tang reads as follows:
409 E8T NO
610 309-4
how does this tell me it is a Dana 44?
thanks for the help
Old Nov 26, 2005 | 03:44 PM
MustangGT221's Avatar
MustangGT221
If it's an F-150 it's a d44...
The 88 is for a ford 8.8 axle (8.8" ring gear). You have 4.10 and 4.09 gears rear/front respectively, according to the tag. The other information is just info like build date/location etc.
Old Nov 26, 2005 | 03:45 PM
andym's Avatar
andym
It would help if we knew what vehicle this came from.
From the rear tag, it looks like a limited slip 4.10 axle. Yes, the 88 means a Ford 8.8" axle. I don't know what you mean by "change anything in the pumpkin or the replace the whole thing", though. Can you make your question more specific?
Nothing on the front tag tells you it's a Dana 44. What truck is this from? How many lug nuts?
phoneman91's Avatar
phoneman91
I think that you are missing a "4' in the tag of the rear differential. It should read 4L10.
And the front differential is a 4.09. And it is open. All F150s 4x4s have the Dana 44 front axle. And all have the 8.8 Ford corporate rear axle.And no--the 8.8 doesnt have a removable third member--like the Ford 9 inch.
You have a rare option--4.09/4.10s LS differentials--I looked for several years before I found my F150 pickup with these ratios. Most 4x4 F150s of this vintage are 3.54/3.55 gears--in my Rocky Mountain area of the country.
Old Nov 26, 2005 | 03:58 PM
scouterspokane
the truck is a 1988 f150 xlt lariat
https://www.ford-trucks.com/user_gal...&albumid=15527
I did miss the "4" in the 4L1088 line on the tag
as to change...you answered for me, I didnt know what I had, so I was looking for advice as to more torque to the wheels by changing the axle or the inside of the axle.
since it cant, should I keep this or look for a different axle?
I also read online about welding the axle tubes to the housing, should this be done?
Thanks...
Old Nov 26, 2005 | 04:19 PM
phoneman91's Avatar
phoneman91
Thanks...
Count yourself lucky to have 4.10/4.09 gears with those tall tires that are on your truck. I saw someone on this site that had 3.08 gears and 35 inch tires!!And they wanted to know why their truck didnt have any power after putting on the tall tires.
Old Nov 26, 2005 | 04:24 PM
scouterspokane
andym wanted to know how many lug nuts, 5.
gammatino
Sep 14, 2025 08:51 AM
60F100
Apr 29, 2014 10:34 AM
Fordman9020
Nov 9, 2009 03:59 PM
jhrsmail
Sep 4, 2007 04:44 PM
85camaroman
Jun 10, 2007 08:26 PM
