Transmission shifter problem
Old Nov 26, 2005 | 05:39 PM
learpilot's Avatar
learpilot
I recently restored a 1963 Galaxie 500 XL with a 4 speed manual trans. I now find that when I change gears, in particular going from 2nd to 3rd, if I 'm not real careful the shift lever moves but the transmission stays in 2nd. This causes me to have to stop shake the shifter around until it seem to "find " it correct location and then I can shift. Can this be corrected using the orginial shifter or am I going to be forced to go to an after market, shifter such as Hurst? Does Hurst even make a shifter that will work here? Thanks
