Recommended Tap and Die set
Old Nov 24, 2005 | 09:33 PM
F250Rob's Avatar
F250Rob
I've been off line from FTE for most of the summer working on a playhouse/swingset project for the kids. (Figured they'll only be 5 and 2 once, while the truck isn't going anywhere...).
Now it's done, they're swingin', and I'm free to get back into the garage!
With that in mind, I'm drawing up the Christmas wish list for tools. One of the top items is a good (complete!) tap and die set.
I'm guessing the high speed steel is worth the extra money when compared to the cheaper carbon steel sets. What do you guys think?
Old Nov 24, 2005 | 10:01 PM
xfordman's Avatar
xfordman
Rob...I got my set from Sears probably twenty years ago. I have no idea what their made of, but they sure are hard! They've seen a fair amount of use in all those years and they look new, no signs of wear and never broke one. BTW, I use cutting oil.
_____________
XFM...
Old Nov 24, 2005 | 11:19 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Thirty five years ago the wife bought me the complete Sears Craftsman set in the walnut box for college graduation. Big money for us at the time. Today that set has it's own drawer in the tool cabinet. I'd suggest buying the most complete and highest quality set you can. You'll never regret it. Stu
Old Nov 24, 2005 | 11:41 PM
Randy Jack's Avatar
Randy Jack
Rob -
I went with a low buck set from Harbor Freight. I have had sparing use for them, although I was very glad they were there when I did need them. The taps and dies cut OK, but the handles suck. Get the good ones.
Old Nov 25, 2005 | 12:31 AM
sierraben's Avatar
sierraben
Irwin/Hanson also makes a nice tap & die set.
Old Nov 25, 2005 | 09:47 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I have a cheap-o set I picked up at a garage sale (Taiwanese) for a couple bucks, and use it for cleaning threads, straightening burrs, etc but would never use them for tapping out a hole in an engine block or other critical hole (especially pipe threads). I have a handful of common sized Craftsman and Hanson HSS pieces for that. The CS pieces have a habit of cracking off when the going gets tough. They are tough to get out if they break off!!
Aside from the material being inferior, the cheap ones don't seem to be consistent in size or thread profile.
Old Nov 25, 2005 | 10:17 AM
4tl8ford's Avatar
4tl8ford
Buy the Best - Cuss the Rest.
Old Nov 25, 2005 | 10:57 AM
truckdog62563
Not exactly on subject, but you guys will I think get a grin out of this. I went to an estate auction at an old closed up hardware/auto parts store here in town a couple of years ago. I came away with this old Ace/Hansen display case will almost all taps and dies in place. They're the old round style dies. I don't use these, just admire them on the bench. Stu
Old Nov 25, 2005 | 11:12 AM
fking1's Avatar
fking1
High Speed Steel a must. Take it from an old time Diemaker. Harbor Freight sets are OK and cheap.Sears much better quality and cost more.
Fred
Old Nov 25, 2005 | 11:34 AM
bobj49f2's Avatar
bobj49f2
Not exactly on topic either but just a tip about broken taps, I drill and tap 12 guage steel all of the time and use a drill to spin the taps because I usually drill and tap at least fifty-sixty holes at a time it saves time. Once in a while I'll snap a tap off. The best tool to use for removing the broken tap is a spring punch. About a half dozen rapid punches and the tap falls apart. Remember the safety glasses, when the tap shatters it flies all over.
Old Nov 25, 2005 | 04:38 PM
49willard's Avatar
49willard
My sears set has to be 25-30 years old. It is high speed steel. I use it often. I would not buy a cheap set.
Old Nov 25, 2005 | 05:13 PM
286merc's Avatar
286merc
I bought a Tungsten steel import set a few years ago as the old set of my grandfathers was getting way worn out. It is 85 piece SAE and metric. Cost around $75 and use it regularly with no problems. Always use a good cutting oil, my preference is Tap Magic.
Old Nov 25, 2005 | 10:09 PM
3Mike6's Avatar
3Mike6
I've an old Ace-Hanson set thats done okay for me...it's probably 30-40 years old.
One thing I've noticed in buying taps over the years, is the chrome finished two flute taps, seem to be tougher than the grey-metal looking 3 flute taps.
Anyone else notice this too?
