need header/oil dipstick solution!
Old Nov 24, 2005 | 08:51 PM
fordeverpower's Avatar
fordeverpower
I was wondering you some others are doing about this. I have an FE block so the dipstick goes through the oil pan. Initally after putting the motor together, i was unsure what to do, as the headers looked like they were in the way. Right now i have a sawed off dipstick just to plug the hole but not knowing the oil level makes me worry especially with the rpm i like to turn.
Old Nov 24, 2005 | 09:14 PM
Bear 45/70's Avatar
Bear 45/70
Tube bender will adjust the tube to fit between the headers. No dipstick is asking for trouble. In my '69 Torino Cobra race only car with the 428CJ, I didn't run one, but I had a sight tube in the side of the deep sump oil pan and just a glance under the motor told me what I need to know. The tube was put in so we could monitor the oil level in the pan at different RPM on the dyno and not have to worry on the track. That system wouldn't work for me today, cause it would take me a half hour down and a half hour back up. Damn the floor gets low every month.
Old Nov 25, 2005 | 12:00 AM
zsir's Avatar
zsir
on my 390 the dipstick goes into the block, but it wasn't going to fit right with headers. I got a dipstick tube out of a 3.0L aerostar and modified the mounting bracket. The stick is out of a 3.8L tarus. Works good ....
Old Nov 25, 2005 | 08:14 PM
ceetwarrior's Avatar
ceetwarrior
My dipstick too goes through the block. I just bent it slightly and bolted it to the headers just like the old manifolds. You must have somethin' funky?
Old Nov 25, 2005 | 09:27 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
4x4 trucks, the dipstick goes into the pan - maybe other applications too, most passenger car dipsticks go into the block.
A little ingenuity goes a long way Just bend the tube to where you need it, as long as you don't make too sharp of a bend.
Old Nov 25, 2005 | 10:17 PM
fordeverpower
well, i got something rigged up. i don't like it but it will work. thanks Guys!
jniolon
Sep 5, 2016 12:00 PM
jeff14346
19
Mar 18, 2015 08:57 AM
460 FORD MAN
27
Jan 28, 2015 11:47 AM
Tigger!
20
Apr 15, 2013 01:15 PM
andrew1
Nov 13, 2010 09:18 PM
