Split Pattern Cam Needed? what specs?
Old Nov 24, 2005 | 01:02 AM
BLUEMERC's Avatar
BLUEMERC
Question Split Pattern Cam Needed? what specs?
My current build is on a budget and is for the wifes car. Low end grunt & mileage are the main concern. I have a STOCK 81 302 2bbl with late 80's factory headers, an AOD and 3.27 Traction-loc with 25.5" tires. 3.73's are sitting on the shelf for installation at a later date. I am looking to find a stock 4bbl to put on also.
I have been looking for a cam and wondered with the early 80's heads are the dual patterns better? I can get some 85 heads if these would be much better. What cam specs would you reccomend?
Thanks,
BLUEMERC
Old Nov 24, 2005 | 06:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Nov 24, 2005 | 07:04 AM
ken75ranger's Avatar
ken75ranger
Welcome aboard. If mileage is a concern don't go to the 3.73's. They would do ok for a 29-30 inch tire. For the heads some one here will know more than I do. I bolted up some y303s that I bought cheap. You really need your entire setup ready to go before you pick a cam. You would need a slightly different one for each variable right down to the stall of your torque converter. When you get all the parts together your going to use call comp cam and they will reccomend the right cam to work with your set-up.
Old Nov 24, 2005 | 09:18 AM
fordeverpower's Avatar
fordeverpower
A dual pattern camshaft is needed for most all ford heads. The 302 is no exception. I don't think the e5ae head is much better tha the d8oe so i wouldn't worry about that. I got to look up the cam specs, that doubletime on holidays.
Old Nov 24, 2005 | 09:24 AM
fordeverpower
Heres a lunati voodoo 61000
250/256 advertised duration
207/213 .050
.466/483 lift
112 lobe seperation
108/116 centerline intake and exhaust
idle -5000rpm
This cam is perfect for what you mentioned.
1972RedNeck
19
Dec 7, 2016 06:51 PM
ford390fe
62
Mar 18, 2012 11:36 AM
Weberman3
May 28, 2011 10:24 PM
pintoches
May 17, 2011 08:15 AM
cfrives3
1978 - 1996 Big Bronco
May 21, 2007 06:03 PM
