1978 - 1996 Big Bronco
Which cam?
Old May 15, 2007 | 10:12 PM
cfrives3's Avatar
cfrives3
Which cam?
What cam would be a good upgrade for the stock 351W? If someone can give me the specs on the stock cam, that would be helpful too. I am looking at a comp cams extreme 4X4 cam kit. If I had the specs of the stock cam specs, it would help in choosing the lift, duration etc. Thanks
Old May 20, 2007 | 06:41 PM
fishin machine's Avatar
fishin machine
What's it going in? Is it EFI or Carb, Speed density or Mass Air?
Old May 20, 2007 | 08:31 PM
cfrives3's Avatar
cfrives3
It is going on a carbed motor. It is stock except the edelbrock carb.
Old May 20, 2007 | 08:40 PM
fishin machine
The stock cam should be right around .444" ex and int from what I remember.
Old May 20, 2007 | 09:11 PM
cfrives3's Avatar
cfrives3
There is another thread in the small block forum on this, quite informative. I am having serious troubles getting this thing running right, with threads both here in the bronc forum as well as in the small block forum. I am hearing good things about the comp cams extreme 4x4 cam kit. It's only $180.
Old May 21, 2007 | 07:32 AM
fishin machine
Just call each of the cam companies you're lookin at and tell them what you want. That's what I did, told them everyting I planned to do to the motor and what I wanted to get out of it, how it was to be used. Then see what they suggest and pick the one that best suits your needs.
Old May 21, 2007 | 12:00 PM
peppersfords's Avatar
peppersfords
Amen brother! That's the best thing you could do. Just remember to go low on the Lobe seperation...to get the really cool idle!
What are you looking to do anyway?
Old May 21, 2007 | 05:39 PM
cfrives3's Avatar
cfrives3
This is to be the wife's daily driver. It will pull my quad tailer, which rarely has less than 4 quads on it. She wants something that "sounds mean and will keep up with the '65" So we would like to hear it lope. But I am hoping to get decent mileage too. I understand it is a v8 4 barrel, but we do understand the idea of keeping our foot out of it. Has anyone checked either of my other two threads about what I'm going through? This is a nightmare. For a $200, it's almost starting to not be worth it. But I'm now into it for almost $1000 so I kinda can't quit now.
P.S. That 1k is just motor stuff.
Old May 21, 2007 | 06:03 PM
Netfly's Avatar
Netfly
Here are some parts I used on my 351w build with good results:
Edelbrock cam 204/214 448/472
http://store.summitracing.com/partdetail.asp?part=EDL%2D2182&autoview=sku
and Comp Cams roller rockers with rails:
http://store.summitracing.com/partdetail.asp?part=CCA%2D1431%2D16&autoview=sku
those require screw in 3/8 studs.
FLgargoyle
Jun 5, 2017 03:50 PM
pintoches
May 17, 2011 08:15 AM
mattb2179
Jan 4, 2011 09:35 PM
70torino429
May 15, 2009 10:07 PM
fordguy76
Aug 1, 2006 03:14 PM
