Gear Selector
Old Nov 23, 2005 | 01:20 PM
wolfalp's Avatar
wolfalp
Gear Selector
I get the great call from the wife today. "The car wont go in Drive or Reverse I had to drive home in 2nd"
I live not so far away from work so I go home for lunch. Not low on Tran fluid like I thought so lets check it out. The gear selector no longer makes it way to park at the left. Move over to the right into reverse and its pointing to neutral etc. Anyone heard of this? I think it must be in the plastic indicator but not sure.
'99 expe
Old Nov 23, 2005 | 05:12 PM
ranger88a's Avatar
ranger88a
Does the lever seem loose and sloppy? If it does, the shift tube broke, or the bolts on the back of the tube that bolt the shift cable bracket to the tube came loose.
Old Nov 23, 2005 | 05:13 PM
wolfalp's Avatar
wolfalp
The actual lever does not feel loose. The pointer is behind the gauge glass (plastic) but it seems to move fine just not on the right target.
Old Dec 8, 2005 | 11:33 AM
99ExpeditionXLT's Avatar
99ExpeditionXLT
Plastic Adjuster
I have had this problem also. Mine was up under the dash where the cable adjuster is for setting the transmission pointer. The plastic piece was broken, so I used a plastic tie wrap to hold it together. It consisted of a thumb wheel that is turned to lengthen, or shorted the cable. This adjusts your pointer. This only affected the visible pointer position and not the operation of the transmission, although I could see how you would select something other than drive, if you were using the visual location of your pointer. Hope this helps.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Dec 8, 2005 | 11:38 AM
COramprat's Avatar
COramprat
So it is able to select the gear?
Old Dec 8, 2005 | 02:31 PM
ford390gashog's Avatar
ford390gashog
so what was 2 could have been drive. or it has broken at the transmission. it is bolted to the shift arm on the side.
Old Dec 8, 2005 | 04:40 PM
Luzer27's Avatar
Luzer27
This is a common problem see thread below
https://www.ford-trucks.com/forums/s...hift+indicator
Old Dec 10, 2005 | 11:34 AM
quick35th's Avatar
quick35th
This just happend to my '99 expy today. Man, does anyone know the part # for the new part to fix the problem?
Shane
Old Dec 10, 2005 | 03:21 PM
quick35th's Avatar
quick35th
I called my local Ford dealer today and they had the part in stock. The part number for the fix is XL3Z-7A110-AA, and it cost $20 from Ford.
Shane
HaulStroker
Dec 24, 2015 11:06 AM
smokedog
Nov 2, 2015 06:46 PM
northdakota 67ford
Nov 4, 2014 06:06 AM
danlee
Sep 23, 2013 08:02 PM
thagoldenb
Dec 16, 2012 02:34 PM
