Keypad code lost
Old Nov 22, 2005 | 06:26 PM
BSMART27's Avatar
BSMART27
Keypad code lost
I seemed to have misplaced my wallet w/the code to the keypad and my license w/my address. Anyone know if the code can be changed w/out the original factory pin. This is for an 05 f150 w/les than 1,500 miles and i would hate for someone to find the wallet and decide to throw a party in my truck while im out or sleeping. The manual says it can be changed but i must have original pin and the original will stay functional. Any suggestion?
Old Nov 22, 2005 | 06:28 PM
ford390gashog's Avatar
ford390gashog
the code is permanent. the code is also printed on a tag under the dash.
Old Nov 22, 2005 | 06:39 PM
triple8's Avatar
triple8
It can be changed at a dealer, but will probably cost you $50 or so I was told. I was unware the printed it under the dash. My S-D I had to have the dealer program due to the tradeing dealer the got it from did not give them the pin.
Old Nov 22, 2005 | 07:14 PM
xtrm1stang's Avatar
xtrm1stang
That code is permanant and cannot be changed, you can only add other codes. Tha only way to change it is to replace the body security module and that has to be done at a dealer because it has to be programmed.
Old Nov 22, 2005 | 07:15 PM
Bigredtruck1's Avatar
Bigredtruck1
The manual has the information in it you need to reprogram. The factory setting never goes away, you just re-write a new code over it. The factory code is on the receiver somewhere in the truck not sure where.
Old Nov 22, 2005 | 10:26 PM
yardbird's Avatar
yardbird
On the '03 and up Expedition it is on the module above the passenger side kick panel. It has black letters printed on a white tag.
It may be in the same place on the truck.
Here is a link to the thread with pictures of where to look.
https://www.ford-trucks.com/forums/s...d.php?t=387911
Old Nov 22, 2005 | 10:38 PM
ATCS2004's Avatar
ATCS2004
I believe you have to remove the rear seat to get to the code, so it's probably easier to have the dealer pull the code for you. When I picked my truck up it didn't have the card. I had to have the dealer pull the code from the body module. It took them about 15 minutes and I didn't have to pay a dime, but I noticed it before I ever left the lot. As stated previously, the code in the module is permanent. If you have the original code you can reprogram your own personal code, but the other code will remain.
Old Nov 22, 2005 | 11:24 PM
PaulC's Avatar
PaulC
Right, so you would end up with two codes. The factory original and a custom five-digit code. The other solution is to electrically disconnect the keypad.
Old Nov 23, 2005 | 07:29 AM
gpeade's Avatar
gpeade
BSMART27,
While I cannot truthfully answer your question I will say this. Don't sweat it. More than likely if someone does find your wallet the most they would do is take any cash and credit cards if you have any. I doubt most people would be interested in tracking down and getting inside your truck. Either way from what I have read here it's not much you can do to prevent it.
Don't worry about the things you cannot control!!
Old Nov 23, 2005 | 03:08 PM
BSMART27's Avatar
BSMART27
Thanks for all responses. I guess i'll take it to the dealer unles it is easy to disable because my license and address was in it. Dont think i'll ever use it anyway. If it is easy to disconnect can you give some direction. thanks again Bsmarter than i was.
xTraveler
May 26, 2024 10:21 PM
acelliott
May 15, 2021 01:06 PM
osheam
Sep 14, 2015 07:41 PM
johnzenobia
2009 - 2014 F150
Apr 27, 2015 11:16 AM
scooterman320
2004 - 2008 F150
Feb 6, 2006 11:05 PM
