Modular V10 (6.8l)
Will 4.30 Gears Be enough???
Old Nov 22, 2005 | 12:40 PM
Nebraska's Avatar
Nebraska
I am looking into ordering a F350 Crew Cab Short box SRW 4x4 with the 4.30 LS. My plan is to install a 6" lift and 37's. Would the 4.30 gears be enough? I do not haul or pull anything other than my quad, but still want usable power.
Thanks
Nebraska
Old Nov 22, 2005 | 12:45 PM
Monsta's Avatar
Monsta
Sit. Stay.
Rpms at 60 in OD
4.30 w/31.6's (stock) = 1976
4.30 w/37s = 1688
Personally I'd say no.
4.56 w/37s = 1790
5.13 w/37s = 2014 <-------- My pick.
Old Nov 22, 2005 | 12:54 PM
Nebraska's Avatar
Nebraska
Would the lower RPM give better mpg? Not that I am going to squable over 1-2 mpg. Would the 4.30's be really that bad for everyday driving? I would love not to have to regear.
Nebraska
Old Nov 22, 2005 | 02:58 PM
Monsta's Avatar
Monsta
Sit. Stay.
I think you may actually return WORSE mileage with the 4.30s and 37s. (Just my opinion)
I can see you using the gas MORE to get up to speed. Sure you'll get better mileage on the highway due to the 300 less RPMs you'll be turning versus stock BUT the slighest incline or desire to speed up will drop you into 3rd (even 2nd) so I cannot see any real mileage benefits.
Maybe you should consider smaller tires? I know, that's a tough one because these trucks look real purty with 6" of lift and 37s.
Just look at this Excursion with 18's and 37's.
Maybe drop him a note asking how his PSD (w/3.73s) handles the 37s.
Eddieelliot438
Old Nov 22, 2005 | 06:04 PM
Nebraska's Avatar
Nebraska
I agree these trucks look soooooo good with 6" and 37's. I like the 35's and 4", but the 35 MT's at 4 Wheel parts are more than the 37's!!! Thank you for your help.
Nebraska
Old Nov 23, 2005 | 09:24 AM
igotoneforya's Avatar
igotoneforya
I have 3.73s and 35s and plenty of power. I would think 37s and 4.30 would be similar if not better than my situation. I have not pulled more than 4000 lbs. If I did, I would change something. I barely lost any mileage. Just got 13.9 on a litle run averaging 72-75. Verry happy.
Old Dec 5, 2005 | 09:36 PM
skinner00's Avatar
skinner00
i have 38's with 3:73 gears, it has power but i need to change the gears out.
Old Dec 6, 2005 | 06:14 AM
igotoneforya
Nice to hear the V10 can move 38s with 3.73. I figured I would change the gears if I went to 37s or 38s. Now I am closer to a supercharger than gears.
Old Dec 6, 2005 | 08:06 AM
BFR250SD's Avatar
BFR250SD
Get bigger gears. No if, and's, or but's. Big tires need new gears.
I run the 36's and had 3.73's, the truck was suckin' with that setup. Now it has 4.56's and I'm still thinking I should have gone 4.88's.
Of course, you can always let your tranny cope with the added stress.
Old Dec 11, 2005 | 10:39 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Originally Posted by Monsta
Rpms at 60 in OD
4.30 w/37s = 1688
4.56 w/37s = 1790
i think it would be ok...look at the numbers with stock tires and 3.73's at 60 in od...depending on what you do with the truck...if your going to be towing/hauling alot, i would regear to at least 4.88's
1709rpm@60 in od
renyren
25
May 8, 2018 12:41 PM
DCP
Sep 25, 2013 04:26 PM
trucktech
Mar 28, 2011 10:31 AM
AlaskaJeff
Oct 15, 2009 10:37 AM
FordF150_1996
Modular V10 (6.8l)
37
Aug 23, 2003 08:04 PM
