Fuel tanks
Old Nov 21, 2005 | 12:29 AM
1970Custom's Avatar
1970Custom
Fuel tanks
how many of you have moved the tank from behind the seat to under the bed?
What tank did you use and did you fill in the big hole?
Old Nov 21, 2005 | 07:57 AM
4Cammer72's Avatar
4Cammer72
96 ford ranger tank inside the frame rail is what i am using.
Old Nov 21, 2005 | 10:09 AM
Outlaw08's Avatar
Outlaw08
I wasn't aware you could move it, how hard is this to do and what does it cost usually?
Old Nov 21, 2005 | 12:46 PM
4Cammer72's Avatar
4Cammer72
mine cost me 50 bucks for the tank i removed myself. it has a submerged pump already installed. you just need to plumb from the tank to the old lines make some straps for mounting and wire it and get a fuel pressure regulator. you need the regulator because the pump puts out around 40 psi from the v6 models.
Old Nov 21, 2005 | 06:15 PM
1970Custom's Avatar
1970Custom
Is there any other pumps that'll work and pump less psi?
Old Nov 21, 2005 | 06:44 PM
4Cammer72's Avatar
4Cammer72
you could open the tank and replace the pump with a section of line and put a sock on it then get a low pressure inline pump to mount outside the tank but you would be better off with the pump in the tank and a regulator. you would never starve for fuel with it.
Old Nov 21, 2005 | 08:01 PM
baitmaster's Avatar
baitmaster
I yanked both the cab tank, and the two saddle tanks and installed a 55 gallon fuel/tool in the front of the bed. Also made the cab fuel filler go away. Kind of funny to watch the smog guy look for it to check it. the big tank came in handy on my last long trip. That 390 is a little thirsty, so you gotta keep her full.
Old Nov 21, 2005 | 11:54 PM
1970Custom's Avatar
1970Custom
Hey Steve what type of FPR is used?
Choctaw Bob
Aug 3, 2015 03:24 PM
eddieb794
1947 and Older Ford Trucks
Mar 19, 2013 11:26 PM
mike L
Sep 2, 2004 08:44 AM
86ford
Apr 26, 2002 01:25 PM
