Door lock replacement help
Old Nov 20, 2005 | 10:00 PM
Rick2324's Avatar
Rick2324
<HR style="COLOR: #666666" SIZE=1> Just bought a 96 F150, only came with a single key for the ignition and it will not open the doors. Should they open them?, if yes, who and what is the cost to make the changes to the cylinder to match the ignition key?, or should I change the door cylinder and use a different set of keys?, and where to find it?
Thank you,
Rick
Old Nov 20, 2005 | 10:49 PM
chrono4's Avatar
chrono4
no, its two seperate keys. if you pull the cylinder, most locksmiths can make a key for less than 15 bucks.
Old Nov 20, 2005 | 10:53 PM
Rick2324's Avatar
Rick2324
Thank you,
Rick
Old Nov 21, 2005 | 08:04 AM
jroehl's Avatar
jroehl
chrono, I see you have a '88. Back then, the door lock and ignition key were different. My '90 is the same way, but my '93 is different--the ignition and door key are one and the same (square headed key), and the glove box key has the oval head.
Rick, it sounds like someone may have changed either the door lock cylinders or the ignition cylinder at some point.
Jason
Old Nov 21, 2005 | 08:18 AM
frederic's Avatar
frederic
I had lost my original keys, and have been using copies of a copy of a copy keys, which required "fiddling" to lock and unlock the doors, as well as start the truck. So the cheapest/least hassle solution I came up with was to visit the local junkyard, find a truck that had the keys hanging in the ignition, and I tested those keys on that truck, ignition and doors to verify they were the right keys (in a junkyard you never know...). Then I bought the ignition lock and both door locks (and the keys) for $5, slapped them in my truck, and that was the end of that problem.
The particular truck i got the locks/keys from, had two original ford keys, and two copies, sitting on a key ring, so I didn't even have to make copies lmao.
I could have gone the locksmith route, but 10 minutes in the junkyard was faster, and cheaper. I actually installed both locks and the ignition lock and one of the keys on my keyring in the parking lot. Done!
Old Nov 21, 2005 | 09:16 AM
KW160's Avatar
KW160
Originally Posted by Rick2324
<hr style="color: rgb(102, 102, 102);" size="1"> Just bought a 96 F150, only came with a single key for the ignition and it will not open the doors. Should they open them?, if yes, who and what is the cost to make the changes to the cylinder to match the ignition key?, or should I change the door cylinder and use a different set of keys?, and where to find it?
I have a 96 and everything uses the same key.
Old Nov 21, 2005 | 11:25 AM
chrono4's Avatar
chrono4
huh, didnt know that they switched to one key, i thought they always had the two keys untill 96 or 97.
Old Nov 21, 2005 | 01:54 PM
qman's Avatar
qman
Nope, my 92 also has 1 key for doors and ignition and a second key for the glove box.
Old Nov 21, 2005 | 01:58 PM
andym's Avatar
andym
This apparently changed in 1992 then, because my 1991 has seperate ignition & door lock keys.
Old Nov 22, 2005 | 09:06 PM
Cheggie's Avatar
Cheggie
When I replaced my ignition cylinder for wear, I had the local locksmiths rebuild my door lock cyl's to match the new key (to retain one key locking!) These Ford door lock cylinders are very common, so it's an easy and inexpensive proposition. It's well worth it - I think I might have an extra one built for my locking toolbox!
I think it would be under $40 if you remove the lock cyl's (which is easy) and take them to the 'smith with one copy of you ign key.
Old Nov 22, 2005 | 09:22 PM
frederic's Avatar
frederic
It's not supposed to.
Square key for the door, ignition and a round key for the glove box (or truck if it's a car, or floor panels if it's a larger station wagon). Ford's done this for as long as I can remember. My 81 crewcab was like this. So was my 77 LTD II, and my 70 falcon station wagon, and my 69 XL convertible, and my 78 and 79 bronco's.
Old Nov 22, 2005 | 10:15 PM
donnor's Avatar
donnor
keys to success
Yes, Ford changed from the door versus ignition key to a common key with the 92 model year. The change also involved a move from the old "5-cut" key (series 33) to the newer "10-cut key" (series 54). This was, I believe, to meet Federal Standards.
Your 96 has apparently had either the ignition cylinder or the door locks changed at some point during its life. Just an additonal note: In 1996, there was a new key blank employed that had an additional longitudinal groove.
dn.
Old Nov 22, 2005 | 10:25 PM
phoneman71's Avatar
phoneman71
You just dont go back far enough. My Dad's 1961 Country Sedan and my 1963 Falcon Futura both had round keys for the doors and trunk and one sided squared key (placed upside down/keyed side up) for the ignition switch. Fords were a real pain back in the early 60's when it came to keys--always had to have both keys to get into the locked vehicle and to start it. But this was in the days of dash mounted left- of -steering- column ignition switches,vent windows in cars,and factory manual chokes.
I think that Ford changed to one key for both the door and ignition on cars about the 1966 model year.They also changed about that time to the double sided key--that could be inserted both ways.
Old Nov 23, 2005 | 10:01 AM
Rick2324's Avatar
Rick2324
Just had locksmith do the doors keys like the ignitions
Thanks for all the help
Rick
yitzy
Aerostar
Apr 6, 2013 11:51 PM
RA112222
1997 - 2003 F150
Jan 20, 2011 10:21 AM
richardliebert
Jun 19, 2010 05:02 AM
yorxs
1983 - 2012 Ranger & B-Series
Jan 11, 2006 08:22 PM
