well i just bought a 66 F-100 with a 352 and would like to put a little extra hitch in it's giddy up... here is what i was thinkin...
1971 390 block
speed o motive 3.984" stroker crank
fed mogul 9.9:1 pistons
erson roller rockers
performer FE heads (i will hand port them)
texas chill single plane manifold from shelby enterprises(im thinkin this is a little extreme for this motor)
crane cam grind# H2782
D.U.I. dist
hedman headers 1 3/4" primaries, 3" collector
anybody know what i will have to bore it to to get appx 416 inches?? any ideas or suggestions would be greatly appreciated...
I think you have a pretty good overall package. The single plane manifold is the only thing I would change. I haven't looked up that cam, but I'm assuming from the part number that it is a hydraulic with 278 degrees advertised duration. If that is the case, I think you would be good to go with a Performer RPM or a Blue Thunder dual plane.
I think the cam he's referring to is the Crane 343801.
I think you'll like that build.
A .030" overbore would give you 416.7 cubic inches. Final bore size would be 4.080".
About the single plane, according to Desktop Dyno anyway, you would give up a lot of top end horsepower by going to a dual plane. Of course with a single plane, you give up some low end torque. Either way you'll have a fun motor. The choice is yours, based on your priorities.
the kit from speed o motive comes with the 3.984 crank, ford racing stage 1 i beam rods with 8740 bolts, fed mogul 9.9:1 pistons, rings, and clevite rod and main bearings for $1175... rusty is right about the cam i was referring to, the 343801... i still havent chosen a carb yet, any ideas?? i was thinkin along the lines of a demon 870 or somethin close to that... anybody wanna run that in desktop dyno?
Edit: Note that all these are run using unported edelbrock heads. Your number will be higher. How much higher depends on the quality of the porting job.
It seems almost impossible to get a 428 crank for under $300-350.
as near as i can tell the best deal on a 428 crank is to go with the dsc stroker crank for $375.. internally balanced and using chrysler big block rods.. i dont know what pistons ya gotta use or if they're custom or not.. if i can finally talk myself into a 410, thats the setup i'll probably go with.. they just rake you over the caols for a core if ya ain't got it otherwise.. cheapest i can find for a true 428 crank is about $450, turned and ready to go..
