1998 ranger p0340 code 1998 engine ???
Old Nov 20, 2005 | 01:10 AM
rangerdave2's Avatar
rangerdave2
Cool 1998 ranger p0340 code 1998 engine ???
I have a couple of questions. 2 years ago I hade a rebuilt motor installedin my 1998 ranger.(ha ha Joke was on me), turns out the motor come from a junk yard or so the dealer says. anyway ten minutes or less after new motor was installed light comes on. two years later i have to go for emmisions test and fail. computer says misfire detection disabled. buy a new cams position sensor only to find I have purchased a 3 wire sensor and there is a 2 wire sensor on the engine. Get the two wire sensor and stillget the same code. Changed the plug to the sensor and the shaft to the three wire sensor and now get the p0340 code. you name it and I have tried it connect reconnect wiggle 1500 rpm idle test. clear code sometimes comes on right away 0r in a range of 5,10,30,50,100 miles. can a bad timing gear trip this code or should i keep with the wiring and shaft. kind of out of ideas any help or ideas would be great.
Thanks
Dave
Old Nov 20, 2005 | 01:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Nov 20, 2005 | 02:40 PM
Rockledge's Avatar
Rockledge
Welcome.
The 1998 4.0L utilizes Sequential Electronic Fuel Injection (SEFI) which means that the fuel injectors fire seperately in each individual cylinder (as opposed to the earlier "batch feed" EFI systems which fire all the injectors on one side of the engine at the same time). The camshaft position sensor (CMP) is much more critical in the SEFI systems since it's used to "time" the injectors. The '98 system requires a 3-wire sensor, so it sounds to me like you probably got an older engine on the swap, and it didn't have the proper CMP setup.
When you replaced the CMP synchronizer shaft did you make sure the #1 cylinder was at DTC and use the special tool to ensure the timing remained correct?
Old Nov 20, 2005 | 03:01 PM
RangerPilot's Avatar
RangerPilot
And when they swapped engines did they swap the computer? That could create some problems.
Old Nov 20, 2005 | 04:57 PM
Rockledge's Avatar
Rockledge
That's a good point. I'd want to know what computer is in there. It's easy enough to check. I suppose I more or less assumed that the '98 PCM would still be in there, since it's OBD-II and presumably a dealership (or any licensed shop for that matter) would not be authorized to go backwards (to EEC-IV) with regard to something like that. OBD-II emissions system monitoring is much more sophisticated than EEC-IV. There are issues of federal and state law involved.
But then again, I've heard of stranger things happening in the automotive world.
Old Nov 20, 2005 | 05:08 PM
RangerPilot
Yeah, I would be thinking the new computer would not work real well with the old engine.
Random: would the new computer think individual injection and the engine be set for batch fire injection? Just thinking out loud...
Old Nov 20, 2005 | 05:45 PM
Rockledge's Avatar
Rockledge
I don't believe there is any relevant differences between the lower intakes on the earlier and later 4.0Ls, which would mean that the injectors sit in the same position regardless. Therefore, it's only a matter of them either firing sequentially or batch-style, and that's entirely up the computer.
Old Nov 20, 2005 | 06:26 PM
RangerPilot
Ahh ok good to know, thanks.
Old Nov 20, 2005 | 07:34 PM
rangerdave2
No the computer is the original, and the engine is the 3.0 and not the 4.0.The dealer said that the only change was the cps from three prog on 1998 motors to 2 progs on 1999
beech2000
Oct 16, 2024 10:33 AM
wtroger
Jun 27, 2015 06:01 AM
jamull2852
Modular V8 (4.6L, 5.4L)
Sep 2, 2013 04:25 AM
merritt691
1997 - 2003 F150
Sep 27, 2012 11:03 PM
Camp250
15
Apr 24, 2012 05:16 PM
