I have 4 different Air guages and when I check them all against the same tire one righ tafter the other I get 4 different readings.
I have a round dial guage
A digital guage
A long skinny slide out guage
And a different shaped dial guage.
All four of these will give a different reading on the same tire.
Is there any type of a constant I could check them against?
Is there any way to know if one is more accurate than another?
Please help I would really like to know the truth here!!
The tire is a pretty good constant providing there was no change in temperature while you were testing the gauges. Generally speaking you get what you pay for in gauges. If you want an accurate one you have to pay for it. It has been my experience over 40 years of working with compressed air that run of the mill pressure gauges will vary ± 10% although they are advertized @ 2% accurate in the center 1/3 of scale.
haha so I should buy the most expensive guage check my tire then see how much my digital guage is off and just add or subtract that everytime i check my air...
and get my money back for the expensive one haha ?
When I was racing, we would use oil filled guages. Not cheap, but extremely accurate. Depends on your needs. As long as you use the same guage on all of your tires, there should not be a problem. And remeber that the pressure stamped on your tire is a suggested running psi. Depending on load, and desired performance will determine your actual running psi.
The pressure rating on the tire is the maximum allowable. The correct pressure is set by the vehicle manufacturer and is usually located on the drivers door post. Sometimes it is located on the sun visor, glove box door, passanger door post and always in the owners manual.
Running the max pressure will result in a harsh ride and excessive tire wear. Tire stores here in So. Cal. always fill them up to the max claiming thats the safest pressure. I wonder how many tires they sell to replace tires that have worn out in the center from overinflation????
I have found the most accurate gauges (for the money less then $30) are truck guages that go to 140-160 psi. I have returned both round and pencil guages when I tested them against my good gauges and found them way inaccurate.
Of all the guages I've used, I have to agree Dan Tenn. Get an oil filled guage with a short hose and a SCREW ON chuck. Most of the push on guages use a little rubber washer gasket to seal to the valve stem. They do a crummy job of sealing and get worse as they get colder.
The stick guages use a plunger and spring. Not too accurate, but fairly repeatable. You get what you pay for.
Most of the 10 buck round guages are junk. Don't waste your money.
The cheap ($10 - $25) digital guages are not temperature compensated and are not linearly inaccurate. At 29 lbs. they might be plus or minus 2 lbs. At 80 psi they might be plus or minus 7 or 8. They tend to be more inaccurate as the temperature goes down. The expensive ones ($75+) are temp. compensated and self calibrating but I haven't seen any with a hose and screw on chuck.
I've got both a digital and an oil filled. Digital is quick, oil filled is accurate. Take your pick.
I think the whole Firestone fiasco should teach everyone that just because the vehicle manufacturer says to inflate the tires to only a certain pressure doesn't mean its gospel. Ford incurred alot of liability by having people purposely underinflate those tires to allow for a more comfortable ride but ended up causing excessive tire temps which ultimately led to blowouts.
I inflate my tires to what's listed on the sidewall and then just monitor tire wear accordingly. If I feel that I'm wearing out the tires due to excessive pressure I'll drop them a couple of psi, but generally I've had no problems running the maximum pressure aside from a tiny bit of additional harshness over bumps.
