I recently bought a 1985 Ranger. The person I bought it off of said that the motor was recently rebuilt. The way that it runs I hardly believe him. He said it was a 2.8, but the way it runs I can't believe it has even been rebuilt. Could someone tell me how I can tell the difference between engines? This thing needs plugs, wires, and alot of other TLC. Good thing I didn't give much for it huh.
If the engine was ever pulled you can find little tell tale signs if it was.....Like the wiring harness doesn't look like they are in factory positions, or they may have used zip ties to fasten them back down etc. See if any of the bolts, like motor mount bolts look like they ever had a wrench put on them. You just kind of have to look closely at some stuff and see if anything is out of the ordinary. Or look for signs of new gaskets and maybe even a coppression test
I would say it's a good thing you didn't give much for it. 2.8L? Hmm... I guess that may be an 85 Ranger engine, I thought it was 2.9L though. Yep gearheadz got it. Look for "strange" stuff. Wires out of place or zip tied in place, bolts that have been removed and have tool marks on them, bolts on the engine would be a good place to start. I would ask for proof of it from him too, who did it, what parts they used, when it was done, etc.
The 2.9L is fuel injected, but not TBI as I recall. 2.8L is certainly a carby engine. Both are 60* Cologne family v6s, like the 4.0L....
I hope that truck wasn't bought for much, if that lousy running engine wasn't figured out before the test drive that should have been taken....
Gosh, this is like the 3rd post I've seen so far tonight that someone has bought a vehicle that runs like crap and they seem surprised once they get home...then ask for help. I guess the local mechanics are too busy to ask for help with inspections...I know, "No fair, Alfred!", since I have a mechanic friend.
He said it was a good thing he didn't give much, so thankfully he didn't waste his money. I seem to think I have a feeling where some money will be going soon. *slowly turns and looks at the 2.8L*
NOT EVERYONE HAS MECHANIC FRIENDS
I knew when i bought it how it ran. For $150, some spare parts, aftermarket wheels and 33's, I thought it a descent deal, even though i might have to spend a little to get it to run somewhat descent. It has definitely been messed with-wires are all bunched up with tape.
But the real question here is, are there any tell-tell differences apperance wise between the available engines. I just need something to go on.
also the 2.9 didnt debu till 86. the 2.8L like said earlier is a colgne 60 degree engine
it started life in the mustange II and when the ranger went from a package on the F150 to taking over the currier platform in '83 it was the "upgrade" option from the 2.0 or 2.3L I4. it will have a 2bl motarcraft carb on it with tfi ignition. i would suggest converting this all over to duraspark ingnition. problematic areas on the 2.8l are leaking valve covers, valve seats backing out, and having to adjust the valve lash during some time in the life of the engine being that it uses solid lifters and as they wear the lash gets to much play in them. these motor tack out around 5k rpms though i wouldnt turn it harder than 4.5K rpms. these motors are slow about picking up the rpms and take 3 days to get up to speed, especially if you have and auto. they do offer after market parts for these engines like over size pistons, cams, headers, and even a 4bbl intake, though by the time you dump that much money into it you could have swapped in a v8.
also you could either have the c3 auto or the c5 auto transmission, if its manuel and original its more than likely a toyo-koygo 4 or 5 speed these were made by a division of MAZDA b4 ford bought them out. the easiest way to id a toyo is by it haveing a hydro clutch(all rangers have hydro clutches) but it will have an external clutch slave. the FM145 will have a internal clutch slave and it connects in the top of the bell housing, the FM146 is 2 inches longer than the 145 and its line hooks into the side of the bell housing, if by some chance you have a m5od trasmission, it will not have a removeable plate on the bottom and it will have a 1 peice cast trassmision (bell houing and body are 1 peice) though on the ones with removeable bells can only be took off with the trans removed from the truck.
if its 4x4 more than likly you have a Borg-Warner 13-50 t case, these are relatively strong units with lil to no problems
The transmission is a 5-speed from a Bronco II, or so he says. It also has buckets from the same. It is a pretty descent truck for the money. It does have the 2bbl motorcraft. Oh yeah, it is a 4X
