Been having trouble with the ABS light being on. Had the garage run a check on the code and it comes up with C1096. Anyone know what the fix for this might be? I've checked all the fuses and they seem good.
Ooh - this could get expensive. A Google search returned the following data for troubleshooting this problem although the data is for a Ford Protege (http://protege5.ugly.net/04-03.PDF):
• C1096: ABS motor stuck ON when vehicle is started or during ABS operation, ABS motor OFF is commanded.
POSSIBLE CAUSE
• Open circuit, or short power or short to ground of motor relay and/or ABS motor in ABS hydraulic unit and control module (ABS HU/CM)
• Stuck motor relay and/or ABS motor
• Open circuit of ABS motor power supply
• Open circuit of ABS motor ground
