ABS code C1096??
Old Nov 16, 2005 | 03:23 PM
r_b_burg's Avatar
r_b_burg
ABS code C1096??
Been having trouble with the ABS light being on. Had the garage run a check on the code and it comes up with C1096. Anyone know what the fix for this might be? I've checked all the fuses and they seem good.
Any help?
Old Nov 16, 2005 | 03:42 PM
ms6073's Avatar
ms6073
Ooh - this could get expensive. A Google search returned the following data for troubleshooting this problem although the data is for a Ford Protege (http://protege5.ugly.net/04-03.PDF):
• C1096: ABS motor stuck ON when vehicle is started or during ABS operation, ABS motor OFF is commanded.
POSSIBLE CAUSE
• Open circuit, or short power or short to ground of motor relay and/or ABS motor in ABS hydraulic unit and control module (ABS HU/CM)
• Stuck motor relay and/or ABS motor
• Open circuit of ABS motor power supply
• Open circuit of ABS motor ground
JustFixIt
Aug 5, 2015 04:21 PM
hugo69
1997 - 2003 F150
Aug 23, 2010 06:29 PM
fatforty
1997 - 2003 F150
Feb 20, 2008 10:29 PM
aikenmj
3.8 & 4.2L V6
Aug 10, 2007 07:14 PM
