Door light project
Old Nov 15, 2005 | 08:35 PM
cangim's Avatar
cangim
Door light project
I am going to put running lights underneath each door. All evenly spaced three per door. I have made a box that will light up all three lights under the door when that door is opened and all lights will light up when the running lights are on as well. question is, does anyone know if there is a central location for all the door switches? At most I can get the signal just inside the door jam. But a central location would be better. Once done I will post some pictures of the project.
Old Nov 16, 2005 | 08:28 AM
day jefro's Avatar
day jefro
cangim i dont have an answer for you but i would like to know too im a contractor and leave my door open to do paper work i want to put a toggle on my dash to turn my door chime off .iknow just take the key out but my crew likes to hear the radio.hope someone will help us .
Old Nov 16, 2005 | 08:33 AM
cangim's Avatar
cangim
To get rid of the chime, take the covers off the steering column. Turn the key to the on position, there is a little keeper button that you can push to pull the entire tumbler assy out. There should be a black wire with pink stripe or vise versa, don't remember. you can either cut the wire and tape it off or you can pull the ball and switch away. This switch will register if the key is in the ignition. The lights will still chime but the key chime is gone.
Old Nov 16, 2005 | 08:45 AM
Kwikkordead's Avatar
Kwikkordead
Cangim you beat me to it.
Here's my post about it:
https://www.ford-trucks.com/forums/s...d.php?t=300413
Old Nov 16, 2005 | 08:59 AM
day jefro's Avatar
day jefro
thanks you guys respond faster than my dads dmaxx but that aint saying much
bigfinn
Mar 3, 2012 08:44 AM
bobert2412
6.7L Power Stroke Diesel
13
Aug 18, 2011 02:31 PM
ATC Crazy
1997 - 2003 F150
Sep 16, 2006 12:01 PM
Ford Truck Racer
Apr 9, 2006 09:44 PM
SWGROUP
1997 - 2003 F150
Feb 9, 2003 05:55 PM
