Differential Questons
Old Nov 15, 2005 | 02:59 PM
billemc's Avatar
billemc
I am doing the body and paint now, I have addressed all mechanical issues with the exception of the rear end. I know I need some sort of posi-trac or limited slip. I have looked in Jags and others but don't really know what I am looking for. I am running a 390 with upgrades (cam, 60 over, 750 carb, electronic egnition ect.) The stock 3 speed column shift is what I have chosen to keep. Any ideas on a rear end would be appreciated. As much as I have tied up into this truck I don't want to use used parts, I would rather have new, performance equipment. thanks for any ideas. Billemc
'71 XLT
Old Nov 15, 2005 | 03:03 PM
ford390gashog's Avatar
ford390gashog
you just need standard ford 9'' parts. pretty easy to find. if you want a whole new rear end give currie industries a call.
Old Nov 15, 2005 | 03:07 PM
billemc's Avatar
billemc
My Diff. is fine, I just think it might need some help with the increased power. And I dought it has any kind of traction control. Billemc
Old Nov 15, 2005 | 09:20 PM
comertrucks's Avatar
comertrucks
currie can sell you the drop in all set up with any kind of traction device you want, all you do is put it in.
Old Nov 15, 2005 | 10:14 PM
ford390gashog
www.summitracing.com
Old Nov 16, 2005 | 12:18 AM
fordraceboy's Avatar
fordraceboy
randy's ring and pinion sells drop in 3rd members that are cast iron for dirt cheap..
Old Nov 16, 2005 | 06:39 AM
jowilker's Avatar
jowilker
Anything can break, but the stock 9" will take anything the 390 can throw under normal daily driving conditions.
Drag racing with slamming gears could require a custom built unit. IMHO
John :=X06
740buckeye
Jul 25, 2014 07:58 AM
billemc
Mar 10, 2005 02:04 PM
billemc
Feb 9, 2005 07:15 AM
billemc
Jan 24, 2005 03:20 PM
billemc
Dec 18, 2003 12:50 PM
