Chain jumped???
Old Nov 15, 2005 | 02:01 PM
flyflinger's Avatar
flyflinger
Thumbs down Chain jumped???
Truck started running really bad. I can t keep it running and it is backfiring all over the place. I give it gas and it doesn't accelerate. As it starts to rev up it hits a point and then backfires. Then re-revs and backfires. Is it time for a new timing chain? Can I tell without removing the timing chain cover? I would like to avoid a day long job.
Old Nov 15, 2005 | 02:14 PM
ford390gashog's Avatar
ford390gashog
my first guess is the roll pin broke on the dizzy. start there, then remove the fuel pump and check the chain slack.
Old Nov 15, 2005 | 02:27 PM
rusty70f100's Avatar
rusty70f100
Check your timing. If the chain jumped or the pin broke, your timing will be way off.
Old Nov 15, 2005 | 02:46 PM
flyflinger's Avatar
flyflinger
How do I check on the roll pin. That is a new term for me. Do I just pull the dizzy and look at something?
Old Nov 15, 2005 | 02:49 PM
ford390gashog
the roll pin keeps the gear on the bottom of the dizzy inplace. they break and the timing is way off.
Old Nov 15, 2005 | 02:50 PM
fordraceboy's Avatar
fordraceboy
pull the distributor and the roll pin is what goes through the shaft to hold the drive gear on... check your timing before you pull the distributor though...
Old Nov 15, 2005 | 02:51 PM
flyflinger's Avatar
flyflinger
Is it fixable, or do I just replace the whole dizzy
Old Nov 15, 2005 | 03:01 PM
flyflinger's Avatar
flyflinger
I will check the timing roughly by trying to line up the tdc mark on the balancer and then checking under the dizzy cap to see if it lines up. If not then pull the dizzy. Any tricks to that?
Old Nov 15, 2005 | 03:07 PM
rusty70f100
That never works. Go get a timing light if you dont have one.
Old Nov 15, 2005 | 03:12 PM
flyflinger's Avatar
flyflinger
I have a timing light, but i'm not sure it will run long enough to check it.
Old Nov 15, 2005 | 03:17 PM
fordraceboy
doing it that way leaves the possibility of being 180 out... if it wont run long enough though you will have to do it that way... so just make sure it points at #1 or #6 when you get er' lined up... if the roll pins broke you'll have to fish the gear outta the motor most likely, i just had to do that on a small block chevy- a 3/8 long ratchet extension with a couple of wraps of black electrical tape workd perfect if you dont got a extendable magnet.. LOL the things one can come up with in a pinch right? if the pins gone you probably will want a new gear, they get chewed up pretty bad when everything isnt right...
Old Nov 15, 2005 | 04:50 PM
bertha66's Avatar
bertha66
If the roll pin breaks the engine most likely will not run at all. If timing was 180 out, engine will not run. If the timing chain did jump, it will run, but not good. Setting up the engine on TDC on the firing stroke and looking in the dis. is a good way of checking. Doing this the dis. should be pointing at #1.
ColtonMullis
Jan 20, 2014 03:53 PM
ArmyCook
Aug 1, 2011 11:34 AM
OrangeBeast78
Jul 11, 2011 03:20 PM
Sam
May 15, 2011 11:24 AM
notnomis
Jan 22, 2010 02:52 PM
