Sick 95 Psd
Old Nov 15, 2005 | 10:11 AM
Dustin_86's Avatar
Dustin_86
Unhappy Sick 95 Psd
PSD 180K miles. Revs real slow, idels low, NO power, knocks from the passanger side of the motor, Sounds like a straight piped 350 when it goes 2500rpm's+. I get PO 113, PO 106 on a reader. HELP. I was told it might be the fuel filter? I will check that today. would it cause all this. I changed it about 6K miles ago.
HELP.
Dustin
Old Nov 15, 2005 | 10:35 AM
Dustin_86's Avatar
Dustin_86
anyone? Have an Idea
Old Nov 15, 2005 | 12:39 PM
l-m tech's Avatar
l-m tech
the p0113 is a code for the intake air temp. sensor,i couldnt find the p0106 in my book.if you have a exhaust leak(large) then it wont spin the turbo up as fast.if the turbo has a butterfly on the exhaust outlet of the turbo it could be stuck shut.i'll keep looking for the p0106 code.
Old Nov 15, 2005 | 01:34 PM
Dustin_86's Avatar
Dustin_86
So what do I look for and replace? Exaust sounds normal untill 2600rpm's then louder than... well a piped 350. It would make sense about it being gutless IE floored and only getting 45mph. with no turbo, wastegate closed. What about the knocking. I thought it was 2 possibly 3 injectors.
Old Nov 15, 2005 | 09:35 PM
wycowboy's Avatar
wycowboy
exhaust backpressure valve?? could be stuckshut by a bad airtemp sensor..you could just disconect the EBPV and if it fixes it you have it licked J
Old Nov 16, 2005 | 07:29 AM
1997F-350's Avatar
1997F-350
i agree and also do you have a kitty still hiding under your truck? i would think at 180k it will be very hard for your truck to exhale through that piece of junk cat.
Old Nov 16, 2005 | 11:33 AM
Dustin_86's Avatar
Dustin_86
She is straight piped= zero cat. I found out that is was the injector control module(sp)
Purs like a PSD should, What would would cause injector module failier?
Old Nov 16, 2005 | 02:57 PM
1997F-350's Avatar
1997F-350
water is the #1 reason i have heard of by far. did you try someone elses to get it running?
Dustin_86
Apr 16, 2005 02:37 PM
Dustin_86
General Automotive Discussion
95
Mar 30, 2005 08:35 PM
Dustin_86
3.0L V6
Feb 11, 2005 07:56 PM
Dustin_86
Dec 19, 2004 12:11 AM
Dustin_86
Dec 8, 2004 10:33 PM
