Let me clarify about the pre spout removal step. I was doing this to see how the timing would be effected with the spout in and the spout out. I realize that it is a wasted step but I just wanted to see the difference. I didnt mean to start any controversies.
Something else with the comments about vaccuum, I hooked a vacuum gauge to the plenum to get a reading while running. It would sweep from 14-18 inHg while idling. Or it would read 13-15 inHg. I dont recall if the vacuum is supposed to be steady or a little fluctuation is normal. There does seem to be a little miss while idling.
At idle, unless you turn something on that changes the drag on the engine (i.e. a/c compressor or a LOT of extra lighting, the vacuum level should remain constant. It shouldn't even fluctuate much when going from curb-idle to in-gear idle. A couple inches maybe.
BTW I don't view it as controversy just a method of clarification and a closer look at what actually was done. Healthy debate is a good thing. Keeps you sharp.
There is a coolant leak, I would guess from when I replaced the water pump. Once the pump is removed I thought it would be a good time to check the timing chain for wear. Besides the balancer is there anything else that would need to removed, to get the timing chain cover off?
now we might be getting warmer, fellas! could it be, just possibly, maybe even, somewhat likely that you might have an INTAKE PROBLEM??? (ie: HEAD GSKT, MANIFOLD GASKET, ETC. ETC.)
