Sponsored by: Auxito
Chattering coming right rear wheel..
Old Nov 14, 2005 | 01:06 AM
copyminkey's Avatar
copyminkey
I have a 98 F-150 and i just rotated my tires recently, and soon aftere that I started to hear this chattering comnig from the back right wheel. I only does it at slow speeds or when i go over bumps. I thought it was my center hub cap but it is plastic and it sounds like metal clanking together.
My truck has a 7.5 fabtech lift on it but I dont think that has an affect on it. Im not sure if its my drum brakes or my axel. so if any one has this same problem please let me know what you did to pix it.
Thanks
Old Nov 14, 2005 | 09:16 PM
Ultramagdan's Avatar
Ultramagdan
Hello copyminkey and Welcome to FTE!
I would check the rear shock at the wheel. A worn bushing on a shock can make a ton of noise. You could also check the lugs on the wheel to make sure everything is tight. I really doubt it's your brakes or the axle.
mechelement
Jul 20, 2010 06:36 PM
superduty4x4
Aug 4, 2008 04:29 PM
Skandocious
Feb 19, 2007 07:47 PM
Blu_Phx
Jan 3, 2006 11:31 AM
Puddin1974
1997 - 2003 F150
Sep 16, 2004 10:24 AM
