'83 F350 6.9 help
12-25-2005, 12:54 AM
on
Ok, I ordered a new I.P. let's see if that take's care of the problem. Does an I.P. come already timed?
Mo Lones
NiceGuyLones(at)juno.com
Desoto, KS 66019
(913)499-5291
12-25-2005, 01:31 PM
Timing is set by the position the IP is bolted to the engine.
Just like a distributor in a gasser.
If you bolt the IP with the static timing marks aligned you will be close.
01-25-2006, 12:35 AM
on
6.9 Man, I just jumped in here tonight. If you have not gotten your truck running yet I could maybe come over an help. I'm located just outside Paola. Drop an email if you need help. len
01-25-2006, 01:24 PM
on
I have been waiting to install my new starter. I work everyday, as of late, so I haven't had time to take the old starter out yet.
zlusmc
05-26-2011 12:10 AM
kjf-250
05-20-2010 07:55 PM
black95tt
17
10-02-2007 12:10 PM
hailstone
23
12-13-2005 04:18 PM
Skaterock
02-04-2004 03:40 PM
16 ,
4x4 ,
83 ,
bad ,
crewcab ,
engine ,
f350 ,
ford ,
fuel ,
fusible ,
ga ,
injector ,
lamp ,
link ,
pump ,
shutoff ,
solenoid ,
symptons ,
temp
