Compression test adapter
Old Nov 13, 2005 | 11:45 AM
smiller4597's Avatar
smiller4597
I am having no luck finding an adapter for my compression tester to test my diesel. Anyone have any resources to help? Thanks, Scott.
Old Nov 13, 2005 | 01:24 PM
Dave Sponaugle's Avatar
Dave Sponaugle
NAPA or Snap On should have the adapter to screw into the glow plug hole.
Old Nov 13, 2005 | 01:27 PM
smiller4597
No luck with Napa, will try Snap On next time he is on the mountain.
Old Nov 13, 2005 | 01:56 PM
PLC7.3's Avatar
PLC7.3
Is your compression tester capable to handle1000psi, your standard car tester will not handle it........
Snapon may charge as much for the adapter as these guys do for the whole setup.
http://shop.store.yahoo.com/hm-performance/testers.html
Old Nov 13, 2005 | 08:53 PM
smiller4597
My tester will handle 600 psi. Why in the world would I need 1000 psi??? Max stock compression is 440 psi.
Old Nov 13, 2005 | 09:44 PM
PLC7.3's Avatar
PLC7.3
Well your tester may do the job as required........but the compression is up around 500 for most engines with under 200K on them. If your quoting the Ford shop manual numbers they are lower than actual readings.
If your handy with a welder try making an adapter from an old GP..... or the 5.7 Chebby adapter will work.........
truck7575
36
Nov 1, 2015 02:40 PM
Shawn 82
Sep 2, 2014 08:12 AM
CobraGT40
Jun 20, 2014 06:34 PM
Dan V
33
Apr 9, 2014 08:37 AM
carrcreekcaller
21
Jul 26, 2013 07:42 PM
