Well your tester may do the job as required........but the compression is up around 500 for most engines with under 200K on them. If your quoting the Ford shop manual numbers they are lower than actual readings.
If your handy with a welder try making an adapter from an old GP..... or the 5.7 Chebby adapter will work.........
