Sponsored by: Real Truck
Line-X Wheels
Old Nov 12, 2005 | 09:16 PM
Customz's Avatar
Customz
Line-X Wheels
I have some argent steel wheels that I would like to have black. Problem is all the black wheels I have found are not the right size or offset. So that leaves me to paint the stockers which would be inexpensive and would probably look that way too. Recently the option of rhino lining or line-Xing them was brought to my attention.
How do you guys think that would work and look?
Would the tires need to come off for application? Would it be more trouble than its worth?
What do you guys think about scratching and maintanence touchup?
Should I stick with what I got or paint em black?
Old Nov 12, 2005 | 09:22 PM
tvsjr's Avatar
tvsjr
Did you post that enough times?
I'd be worried about the heat... wheels tend to get hot, especially if you tow heavy loads or drive in a "spirited" manner (like me) and get the brakes nice and warm. I bet the LineX would melt off...
Old Nov 13, 2005 | 01:26 AM
NoMo's Avatar
NoMo
While I do have Line-X on a good portion of my truck, I'd never consider having it sprayed on my wheels. Besides adding a good bit of weight to the rim, it'd make balancing the wheel & tire very difficult- assuming you could even get wheel weights to stay attached to the rim.
Old Nov 13, 2005 | 01:38 AM
BFR250SD's Avatar
BFR250SD
I think getting a consistent thickness in the application and balancing them would be the biggest problem.
I would just scuff them up good, get a good quality black paint (gloss or flat, whatever) and take your time and paint them up.
EDIT: Dude, are you doing this to the wheels on your HD? Eeeeeeh, I'd reconsider doing any of that to those wheels, those are pretty sharp looking. If anything, I would tape off the wheel and paint the openings or vice versa. That would give a decent contrast to them.
Kinda like this.
Old Nov 13, 2005 | 01:54 AM
Go Devil's Avatar
Go Devil
I believe the best way to solve your problem would be to have the wheels sand blasted and powder coated black.
Old Nov 13, 2005 | 08:26 AM
wvabeer's Avatar
wvabeer
I took mine to a body shop and they base coat clear coated them for a hundred bucks and for another hundred I bought new chrome caps from the dealer
https://www.ford-trucks.com/user_gal...=94001&width=0
Old Nov 13, 2005 | 01:44 PM
Customz's Avatar
Customz
BFR, the Harley is history, traded it for an 06 cc lb 4x4 PSD.
Thanks for your responses guys, the weight and balancing on the line-x was my main concern and just wanted to hear some confirmation.
wvabeer is what I am ultimately looking for. Did the body shap have to remove the tires from rims? Could they paint the plastic caps?
Old Nov 13, 2005 | 06:13 PM
wvabeer's Avatar
wvabeer
I never tried to paint the caps ,I wanted a little chrome to break up all the black . The guy's at the body shop painted the wheels with the tires on but they removed the weights and reinstalled them my brother uses black spray bombs but has to paint them evey year I wanted mine shinny
Old Nov 14, 2005 | 11:59 AM
emag's Avatar
emag
If your going to paint them try the "Eastwood Co." they have paint specifically for wheels.
kickstand03263
Paint & Bodywork
Aug 15, 2012 10:23 AM
1968 F100 Ranger
Jun 8, 2012 10:48 AM
LARIAT 85
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Mar 9, 2011 06:54 PM
lasitter
Appearance & Dress-Up
Mar 22, 2010 09:29 AM
Gage2502
Mar 20, 2008 04:46 PM
