Sponsored by: Real Truck
brake lights dont work!!
Old Nov 12, 2005 | 05:47 PM
kamaleon's Avatar
kamaleon
Hey guys, I just recently i found out that my brake lights dont come on when i brake. I checked the light bulbs and they are fine, replaced a blown fuse but did nothing..
Any ideas on what to look/test?
Old Nov 12, 2005 | 08:34 PM
Cowboy Brett's Avatar
Cowboy Brett
How about the stoplight switch?
I think you'll find that to be located under the dash attached to the brake pedal linkage.
Old Nov 12, 2005 | 09:00 PM
kamaleon's Avatar
kamaleon
stoplight switch? ill check on that.. i assume to check if the switch stoped working?
Old Nov 12, 2005 | 09:06 PM
white line's Avatar
white line
i had that problem, on mine the bulb was good , it was the ground wire from socket to ground,had corrosion . take a test line check the wire back to the socket and check the ground at the socket.
Old Nov 13, 2005 | 09:19 AM
kamaleon's Avatar
kamaleon
both brake lights went down at the same time.. ill check that anyways just in case
Old Nov 13, 2005 | 01:19 PM
Rongold's Avatar
Rongold
Wink Brake Lights
Get a test light. At the brake light switch, you should have 12 volts at 1 terminal with the brake pedal not depressed, and 12 volts at both terminals with the pedal depressed. The switch is located on the brake pedal arm above the pedal. You can also pull the connector off of the switch and with a paper clip, connect the 2 terminals in the harness together--that will illuminate the brake lights if everything else is OK.
RON
Old Nov 13, 2005 | 03:51 PM
99f350sd's Avatar
99f350sd
Check your hazard switch isn't half way depressed.
Old Nov 13, 2005 | 04:46 PM
kamaleon's Avatar
kamaleon
tried the hazards.. they do work and they are fully de-pressed.
1981Ranger
Sep 22, 2013 06:56 AM
feth91
2004 - 2008 F150
Oct 16, 2011 07:36 AM
offrdmania
Jan 23, 2010 07:03 PM
