Sponsored by: Real Truck
Fuel tank capacities
Old Nov 12, 2005 | 08:17 PM
220KF250's Avatar
220KF250
Harpooning --- diesel guys yes, but it might help the gas guzzler guys, too, from what I read.
I still haven't found that thread I mentioned ..............
Old Nov 12, 2005 | 08:45 PM
220KF250's Avatar
220KF250
I think I finally found the thread:
https://www.ford-trucks.com/forums/a...poon-The-Tank?
Old Nov 12, 2005 | 09:51 PM
Customz's Avatar
Customz
I know of another who suspected a 29er bein put in his long bed...can't remember. I guess you should look under a LB and SB and note the difference. Or you could get a 6 gallon container of diesel take it with you and test it, risky, risky.
I bought the LB for the 38 gal tank and added utility. If it came w/ a 29, you have a valid claim, just look under std features.
Old Nov 12, 2005 | 11:48 PM
shadetree01's Avatar
shadetree01
Does this allow you to put more gallons of fuel in or does it just fill without foaming. My 01 has the 38 gal tank I would like to carry more fuel I'm assuming you can do this on the larger tank also.
Old Nov 13, 2005 | 12:28 AM
Customz's Avatar
Customz
38gal is the largest tank on 250/350 as far as I know unless you go aftermarket. The harpoon allows you to hold more or overfill faster than pumpin slowly in a non-harpooned tank. I once put 30.5 in a 29gal tank. Don't recommend it and won't do that again.
Old Nov 13, 2005 | 07:35 AM
MobeyDick's Avatar
MobeyDick
It does NOT allow more fuel to be put in your truck!! It might allow you to fill it to the top of the neck faster. I done mine and it does NOT help me fill it any faster though.
The 38 Gal tank will hold 42.8 Gals. or at least when I ran mine out that is all I could put in it!!
Old Nov 13, 2005 | 02:24 PM
Redstradic's Avatar
Redstradic
i have a 29 gallon tank and the most i have ever put in was 22. the gauge is very misleading.
RR24
Modular V10 (6.8l)
Jan 1, 2015 02:45 PM
LabCab
6.7L Power Stroke Diesel
26
Mar 17, 2012 12:21 PM
bimmertrek
Mar 22, 2011 03:28 PM
ttexastim
23
Jan 21, 2009 10:51 PM
dapgar
Jan 7, 2007 08:23 PM
