Sponsored by: Real Truck
Fuel tank capacities
Old Nov 12, 2005 | 08:00 AM
Rugby3's Avatar
Rugby3
I know this topic has been covered in various ways and that the spec sheets cover the capacities for both the LB & SB trucks. My question is, has Ford or would a dealership ever have put the smaller tank in a long bed?
I have run my truck down until the fuel light comes on and then filled up. The most I have been able to put in is 29 gallons. I haven't really paid attention to the physical size of the tank when I have been under the truck doing maintenance. Are there any markings on the tank to indicate which tank size it is?
Old Nov 12, 2005 | 08:06 AM
HeavyAssault's Avatar
HeavyAssault
LB=38 gals
SB=29 gals
The thing is Ford's low fuel light comes on with about 4 gals left in the truck. If you top off the filler neck you get about 2gals more into the tank. I would not recommend this for a gas truck due to the fuel expansion. When I had the V10 I would add till the cost rounded the next whole dollar.
Old Nov 12, 2005 | 08:14 AM
Rugby3's Avatar
Rugby3
My sig did not show up in my post. My truck is a 2001, CC LB V10. I do know the capacities for both bed sizes, just curious if anyone has heard of the LB taking so little to fill up.
Old Nov 12, 2005 | 08:18 AM
HeavyAssault
In the owners manual it talks about the "Low Fuel" light and when it comes on. My 99 did the same thing, my 04 PSD does the same thing. It keeps you from running dry before you fuel up.
Old Nov 12, 2005 | 08:25 AM
FortyFords's Avatar
FortyFords
wheel basehad alot to do with it also.
chk your wb center axle to center axle.
your truck if it has a 156 " wb came with 29gal.
172" got the 38 gal
No markings on the tank ,has there been mistakes from the factory? yes!
.from your description you only have a 29 gal.
Rich
Old Nov 12, 2005 | 08:34 AM
Rugby3's Avatar
Rugby3
I appreciate the quick replies, however I guess I didn't make post clear enough. I have the longbed crew cab. I know it's supposed to have the 39 gallon tank. I know the fuel light comes on to warn you, when you only have approximately 4 gallons left.
My question was to find out:
1) if anyone has heard of a dealer swapping out a the larger tank for a smaller one. I don't know anyone would, just a question.
2) Is there a marking on the tank itself to identify it's capacity.
3) What is the average fill for those with the 39 gallon capacity when the fuel light has come on.
I fill it up the majority of the time when it's just below a quarter of a tank and even that is only around 24 gallons max.
Old Nov 12, 2005 | 08:40 AM
FortyFords's Avatar
FortyFords
You have 29 gal,its that simple.
problably a fill when the light comes on would 34 gals
I have a 29 ,so I have no definitive answer for you .
But chk your wb anyway.
Rich
Old Nov 12, 2005 | 10:02 AM
Hockycop's Avatar
Hockycop
I have the exact same situation. I have 1999, SD, V-10, 4x4, SC, LB. I can go down to the red line and only put about 24 to 25 gal in. At half tank it’s right at 15 gal. I’m convinced I have a 29 gal fuel tank.
Bob
Old Nov 12, 2005 | 02:34 PM
220KF250's Avatar
220KF250
I saw a thread earlier today here about "Harpooning the tank". I can't find the link right now but I did happen to read it through and you will find it informative.
If I find it again, I'll try and find my way back here and link it!
Old Nov 12, 2005 | 04:59 PM
Rugby3's Avatar
Rugby3
Bob
So I am not the only one going crazy . I guess I will just have to resign myself that Ford did put in smaller tanks on the longer wheelbases as well. I have also seen the threads about "harpooning" the tanks, seems to mainly be the diesel crowd performing that mod.
On another note, any idea as to why my signature/info isn't showing in my posts?
Old Nov 12, 2005 | 05:45 PM
BareBones's Avatar
BareBones
Actually, it should be easy enough to find out. My tank is almost exactly 5 feet by 1 foot by 1 foot, or 5 cubic feet. I think there's 8.8 gallons per cubic foot, so this would be about 44 gallons, which is probably about right.
So you can determine the size of your tank by measuring its cubic feet.
Old Nov 12, 2005 | 06:28 PM
Rugby3's Avatar
Rugby3
That's a great idea, I didn't even think about doing something that easy. I will measure it in the morning.
Thanks
Old Nov 12, 2005 | 06:48 PM
BareBones's Avatar
BareBones
Actually it may only be 8 gallons per cu. ft., but whatever....
Old Nov 12, 2005 | 08:01 PM
220KF250's Avatar
220KF250
Barebones and others --- there's 7.48 gallons per cubic foot. Easy way to remember is 1-1/2 Jerry Cans per cubic foot ........... which at first glance doesn't seem to add up.
Old Nov 12, 2005 | 08:12 PM
jake00's Avatar
jake00
harpooning is something the diesel guys do.
