How do I "turn the pump up?"
Old Nov 11, 2005 | 05:01 PM
Southtowns27's Avatar
Southtowns27
I have an '85 F-250 with the 6.9 in it. I was hoping to get a little more power out of it. I know I can turn the pump up and advance the timing a little bit, but how do I go about doing either of these? Thanks in advance
Old Nov 11, 2005 | 05:06 PM
IHdieselfan's Avatar
IHdieselfan
you'll have to take the pump to a Diesel shop most can do it for you
Old Nov 11, 2005 | 05:58 PM
Katmandu's Avatar
Katmandu
Arrow
Certainly this can be done at home.
Can someone post of pic of the timing screw on the IP ??
Old Nov 11, 2005 | 09:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The timing screws are the ones that mount the IP to the engine.
The equipment to time a diesel properly costs a couple of grand.
That is why it is best to go to a diesel injection service.
Timing retarded, bad mileage, no power = wasted fuel dollars.
Timing to far advanced, engine damage = lots of wasted dollars to replace the engine.
Price an engine, price a timing job at an injection service, you will see what I mean.
Old Nov 12, 2005 | 02:14 AM
Katmandu's Avatar
Katmandu
Question
Where are they in the pic below ??
What is a reasonable price to pay for Diesel Tune-Up ??
Old Nov 12, 2005 | 05:18 PM
Dave Sponaugle
The first flange on the left labeled driveshaft mounts to the IP drive gear.
The cut away second flange from the left is what mounts it to the engine with three bolts.
Timing set only is about 100 dollars here in WV with current shop rates.
Old Nov 12, 2005 | 06:33 PM
Southtowns27
I get the timing part, but how do I turn the fuel up?
What exactly happens if the timing is advanced too far? I know that's bad in a gas engine since it results in detonation, but what happens in a diesel?
Old Nov 12, 2005 | 08:08 PM
Dave Sponaugle
It depends on how much to advanced the timing is.
Since a diesel fires by detonation if it is to advanced the shock from firing on the compression stroke can break or melt lots of expensive parts.
Pistons, rods and crankshafts are the most expensive ones.
Glow plugs are the cheapest ones.
Do you have a pyrometer Southtowns27?
Also when under wide open throttle do you have any black smoke from the engine at the present fuel setting?
If you don't have a pyrometer you should not turn the fuel up.
If you do have any black smoke under wide open throttle, all more fuel will get you is more black smoke, not more power.
Old Nov 29, 2005 | 01:09 AM
mhannink's Avatar
mhannink
i did my own timing and fueling it worked very well lots of power now just have to whatch it when i let my cuz drive (he tends to get a 6in long flame out the stack) its very easy each mod takes ten min for timing u will need a special tool for getting to the one bolt but after that its cake theres no point in spedning the money to pay some one else to do it this works well when done carefully
Old Nov 29, 2005 | 01:10 AM
mhannink's Avatar
mhannink
i did my own timing and fueling it worked very well lots of power now just have to whatch it when i let my cuz drive (he tends to get a 6in long flame out the stack) its very easy each mod takes ten min for timing u will need a special tool for getting to the one bolt but after that its cake theres no point in spedning the money to pay some one else to do it this works well when done carefully pm me for more details on this and i will try to find some pics to help too
FORDF250HDXLT
166
Jan 22, 2022 01:04 PM
Tim Hodgson
Feb 12, 2015 09:56 AM
bismic
Jul 27, 2014 06:31 AM
BradyCouchman
346
Oct 16, 2013 11:37 AM
joe truck
1983 - 2012 Ranger & B-Series
Apr 1, 2013 08:29 PM
